97 monte carlo
Old Dec 26, 2017 | 06:13 PM
Draglife's Avatar
Default 97 monte carlo
hi I have a 97 Monte carlo and I have no power to the in side of the car and it won't start or even try to crank over batt all good starter good Im lost plz help
Old Dec 27, 2017 | 07:17 AM
Is the battery power wire to the fuse box next to the battery connected? I'd probably start by checking for 12v at each of them to make sure theyre all getting power first.
Old Dec 27, 2017 | 07:58 AM
Smile
X 2 on that.
Fully charged automotive batteries should measure at 12.6 volts or above. When the engine is running, this measurement should be 13.7 to 14.7 volts. check with a multimeter to tell you the voltage of your battery.
This can be more than likely a bad connection or a bad ground cable. Some times the cables get corrosion on them and you will need to clean both ends of the cables. hope this helps
