3800 swap none sc to sc help please
Old Dec 17, 2012 | 09:10 AM
Dam20735's Avatar
Default 3800 swap none sc to sc help please
Ok so I did a swap in my 02 monte Carlo everything is Hooked up now I get to the fuel lines they are different from the none sc can some one help an explaining how do I fit those together an also the sensor behind the supercharger how do i wire that into the new connector
Old Dec 17, 2012 | 09:16 AM
LW57912's Avatar
I was able to use the stock fuel connections on my '02 to the L67 fuel rails. They will be at 90 deg. but should still connect. Make sure they lock into place otherwise they can leak.
If you are talking about the MAP sensor ( the one with a 3 prong plug and vacuum line) then you just need a L67 MAP plug and splice it into your existing wiring. ZZP sells one as well if you can't get one locally.
Old Dec 17, 2012 | 02:30 PM
Dam20735's Avatar
If the fuelrail I got was cut what else can I do
Old Dec 18, 2012 | 06:37 AM
LW57912's Avatar
Without seeing it its hard to say. I'd say get another fuel rail so you don't have to worry about it. I have one I can sell you, but I assume your in the US so you could probably find one there to save on shipping
Old Dec 18, 2012 | 08:44 AM
What supercharged engine did you use?
Series 2 or 3?
Old Dec 18, 2012 | 07:41 PM
PacerSS's Avatar
Try sticking the right hose to the right line. I thought I had the same problem turns out I was trying to fit the small line on the big outlet and vice versa.
Old Dec 19, 2012 | 07:05 AM
Dam20735's Avatar
I have a series 2 motor l67
RattPack
16
Dec 30, 2015 04:09 PM
Denarius23
Sep 17, 2014 02:18 AM
majakarot
15
Jan 24, 2012 01:34 PM
davidk67
Oct 10, 2010 06:48 PM
golfstud2k4
Sep 29, 2010 03:37 PM
