2007 Monte Carlo lt brake bleeding
Old Mar 23, 2025 | 05:24 PM
07_monte_lt's Avatar
Default 2007 Monte Carlo lt brake bleeding
I just did front and rear calipers, new rubber lines all the way around and a master cylinder, I've bled all the brakes in order for farthest to nearest and I still have a very spongey brake pedal, what am I missing and what do I need to do to get this thing to have a solid brake pedal? And comments would be greatly appreciated
Old Mar 24, 2025 | 06:17 AM
(EDIT) Do you have some brakes after trying to bleed them? -Or does the pedal just drop to the floor?
Is everything installed correctly? Meaning, are the zirks at the top of the caliper?
It can take a while. I probably made 20 rounds one time while trying to bleed these brakes. My kid was limping for a day or two lol.
Eventually I made something to do the work for me. Its a simple grommet that holds 4-10ft hoses that plugs into the business end of the shop vac and goes to the bleeders. Mid-line is a bottle to catch all the fluid. Just turn on the vacuum and make some rounds, cracking valves.
Using the traditional way, it could take a few rounds, like I said.
DudeWithThe96
Oct 27, 2021 09:37 AM
Jake Long
19
May 21, 2015 12:22 AM
darksided
Dec 27, 2013 12:40 PM
rickhev1
May 17, 2012 05:30 PM
zapp59
Jan 25, 2009 12:38 AM
