2006 seat ???
Old Aug 14, 2007 | 09:38 PM
twinswin91's Avatar
Default 2006 seat ???
I am considering buying stockblack leather seats ft and back from an 04 monte will they fit my 06 ???
Old Aug 14, 2007 | 09:45 PM
04 Intimidator's Avatar
Default RE: 2006 seat ???
No clue on the rears, but with the fronts you can always make an adapter.
Old Aug 15, 2007 | 11:53 AM
rj's Avatar
rj
My guess is since both cars are pretty much the same car, no reason the seats won't from one won't fit the other.
I know a few '00-05 owners have posted they installed '06 parts on their cars without modifications.
Old Aug 15, 2007 | 11:54 AM
GrandPaDave's Avatar
I'd also guess that they would fit.
Old Aug 15, 2007 | 02:32 PM
My only concern would be with the contour of the rear seat. I'm almost positive it will drop right in, but positive enough to put my rep on the line.
Old Aug 15, 2007 | 07:10 PM
twinswin91's Avatar
Ok I have another question. How hard is this project if everything lined up.
Old Aug 15, 2007 | 09:14 PM
rj's Avatar
rj
You've got the seats setting in your drive waiting to be installed, maybe a couple hours time.
The bucket seats just unbolt. And there's probably a couple bolts holding the bottom cushion of the back seat in.
If your car has a fold down rear seat the back cushion of the backseat will have pivot points that means bolts some place that need to be removed so the cushion can be extracted from the car.
Old Aug 16, 2007 | 05:03 PM
The front seats have the 4 bolts but also the wiring harness for electric heating and seat adjustment.
The rear simply popped out for me when I was doing spring cleaning just by pulling up from the back.
Old Aug 16, 2007 | 10:00 PM
twinswin91's Avatar
are they hard too get to ?? does the 04 seats have the same bolt pattern ??
Old Aug 16, 2007 | 10:40 PM
I would assume the same bolt pattern. I don't think dimentions were really changed for that. It allows easier mass production.
