2003 monte ss heated seat help!!!
Old May 2, 2013 | 03:25 PM
Kenny Guido Temprano's Avatar
Default 2003 monte ss heated seat help!!!
Ok, this is my first car with heated seats. i like the feature alot but for some reason for the past week, the drivers side would not shut off. I adjusted the hi/low switch several times, thinking it was "on", but it never shuts off. i had to unplug it under the seat but now i cant use the power options for the seat, which i knew wouldnt happen. can anyone explain to me why its always on and perhaps how to fix it? thanks!
Old May 6, 2013 | 04:14 PM
ohara's Avatar
My first guess would be the problem is in the switch itself. Never having experienced this issue I am purely speculating, but that is where I would start first.
My heated seat feels like it is shorting out in the back of my left leg when I turn it on so I never use mine.
Old May 11, 2013 | 08:59 AM
thanks. do i have to take the whole center console apart to get to the switch of can i just pop the cover off around the switches?
Old May 13, 2013 | 03:32 PM
ohara's Avatar
Not having pulled the switches myself I don't want to steer you in the wrong direction. From a quick look at my center console it appears as if it would pop out from the console, but I would first open the armrest box and see if it it can be unscrewed and pulled up and out allowing you access from the back. This is just how I would start to tear it apart.
here is a step by step guide that I found on the forum. Hopefully it will answer your questions better than I could
https://montecarloforum.com/forum/ge...ocedure-18196/
Old May 14, 2013 | 03:08 PM
thanks!! i just opened up an new page asking how to take apart the center console. im going to check the link u sent....thanks!!
snider.justin
13
May 31, 2024 06:57 AM
l67ss
Dec 3, 2013 12:22 AM
snider.justin
Jan 14, 2013 01:17 AM
03MonteCarloSuperSport
Sep 22, 2011 11:56 AM
astrojogr
Oct 4, 2010 08:26 PM
