2002 Monte carlo SS removing dash
Old Jul 12, 2009 | 10:23 AM
gaj3236's Avatar
Default 2002 Monte carlo SS removing dash
How dow you remove the plastice dash from around the instruments, radiio and heater?
Thanks, Geo
Old Jul 12, 2009 | 10:53 AM
jimbo7's Avatar
remove the panel under the steering wheel first, then gently pry it off but be careful of the clips. it'll take some force, but don't get too aggressive or you might break something.
oh, it helps if you lower the steering wheel and put the car in 1st gear (use ebrake) so you can get it out.
Old Jul 12, 2009 | 12:51 PM
Enzo354's Avatar
STILL SLOW
Theres a screw in the glove box, and on the side in the drivers fuse box compartment, and then under the dash panel by where your right knee would be about.
Old Jul 12, 2009 | 01:56 PM
NewFoundJoey's Avatar
ok so maybe its just me and my luck but... I Needed my cluster fixed in my dash so i took it to CarMax where i got it from and they messed it up more. my friend works there and he said once you take it off its hard to get back on the way it was. I would say take it somewhere so if they try and give it back to you messed up like they did me you could b**ch till they fix it right
Thegrimreaper
Jun 12, 2012 12:02 AM
BIG AL 070
Jul 20, 2010 09:28 PM
PuppetMaster
May 13, 2007 06:07 PM
krazy92rs
Apr 5, 2005 04:35 AM
