2001 Monte Carlo SS Build (2011)
Thanks For All The Comments On My Build, I've Tried To Make The Pic Smaller
But They Continue To Come Out Super Size I Don't Know Why It's Doing That....
PLZ Take The Time To Check Out My Videos, This Is A Project Car I Bought Back
In June of 2011.... I'm 80% - 90% Complete On The Car It's Self.
Video 1
Video 2
Video 3
Video 4
Video 5
Video 1
Video 2
Video 3
Video 4
Video 5
Mrs. Carla 2.0 In The Making
She's Has Been Brought Back To Life, But It's Not Over Yet.... Her Last Days Before She Transformed.......
Part List... Engine
New Air Filter (Stock)
New Alternator (Re-manufactured)
New Catalytic Converter
New Coil Packs (Total 3)
New Drive Belt (Serpentine Belt)
New EGR Valve
New Heater Core Water Outlets (Top & Bottom)
New Oil Level Sensor
New Oil Pan Gasket (Hard Rubber Gasket)
New Oil Pickup Pump Gasket
New Oil Pressure Sensor
New Oxygen Sensor (Upper & Lower)
New Radiator Hose (Upper & Lower)
New Read Main Seal Kit (Back Plate & O-Ring)
New Spark Plugs (Bosh Platinum) ---> Acdelco is Default Chevy Brand
New Spark Plug Wire Set (Autolite)
New Thermostat W/ Gasket
New Upper & Lower Intake Manifold Gasket
Original Knock Sensors (Front & Rear)
Modified Dog Bone Motor Mounts Bushing
Prestone 50/50 Antifreeze ---> Factory is Dex- Cool (Not-A-Fan)
Part List... Transmission
New CV Joints ( Driver & Passenger)
New Hayden Transmission Cooler (Highly Recommended)
New Output Shaft Seals (Driver & Passenger)
New Transmission Oil (10.5 Qrts.) - Complete Fluid Exchange (12-14 Qrts)
New Transmission Filter
New Transmission Speed Output Sensor
New Transmission Shift Solenoid (1-2) & (2-3)
New Transmission Pressure Control Valve (EPC)
New Transmission Torque Converter Clutch Solenoid (TCC) (OBD II Code 742)
New Transmission Side Case Gasket W/ O-ring
Parts List... Under-carriage/Frame/Suspension
New Ball Joints (Pain In The @$$ To Remove Stock Welded On With Rivets )
New Brakes & Rotors (All 4 Wheels, Brand - Weaver Gold)
New Coil Spring Support (Sound System Added Weight In The Rear)
New Fuel Filter
New Lower Control Arm Bushings
New Outer Tie Rods
New Rack & Pinion
New Wheel Nuts (Complete Sets -20)
New Wheel Studs (Replace 3)
Parts List... Electronic
Diesel Audio X Crossover
Kicker 08CVX12 (3 Enclosed In A Ported Box)
New Alarm (Python 1601 w/ Remote Start)
New Double Din Radio (Pioneer AVH-P3100DVD)
New Hids Kits (Headlights & Fog light) (8k to 10k)
Optima Red Top (1) Under Hood
Optima Yellow Top (1) Mounted In The Trunk
Power Acoustic LFA-1 5500 Mono Amp
Power Bass 6.5 Speaker (4), Power Bass 6x9 (2) & Precision Power 3" Tweeters (2)
Power Bass 800.2x 2 Chanel Amp
Part List... Engine
New EGR Valve
New Fuel Filter
New Outer Tie Rods
New Rack & Pinion
