6th Gen ('00-'05): 2001 Monte Carlo LS
Old Mar 22, 2017 | 08:29 PM
Quincy Williams's Avatar
Default 2001 Monte Carlo LS
So I have this problem with my cigarette/auxiliary outlet an like today it was working just fine until I used a portable air compressor to put air in my tire an it just shut right off so thing is I need to know do I have to change the fuse on the driver side or passenger side please let me know witch fuse
Old Mar 23, 2017 | 01:50 AM
Imp42017's Avatar
There are 2 fuses. One is a 20amp the other is a 15amp. depending on what one you were using when you lost power. These are in the right side. One is called Aux 20 amp. The other is called C/LTR I think. Hope this helps some
James
Old Mar 28, 2017 | 07:59 PM
RickCoMatic's Avatar
Remove the Cigarette Lighter Plug from the Compressor.
Install a pair of Heavy Duty Alligator Clips that will connect to the Battery Posts or Buss Posts where the High Amp Relays are mounted.
Old Mar 29, 2017 | 06:35 AM
corypatterson's Avatar
got the long shift in my 05 monte carlo from 1 to 2nd now im told i can only use a 05 monte tranny r they tryin to squeeze me or can i use 00 to 05 tranny
