11 sec Monte almost ready
Old 08-25-2010, 05:46 PM
PacerSS's Avatar
I'm actually doing a top swap, stage 4 heads, monster cam, Gen V, ported everything, E85 build.
Old 08-25-2010, 05:57 PM
zipper's Avatar
Excellent choice by going to E85 Pacer.
04Turbo, I checked out your thread in the suspension section. Keep us posted on how you do. If you get any kind of traction, I might do something similar. I just can't seem to get any traction with these stock size wheels/tires. The Monte literally will squeal the tires at 45mph.
Old 08-25-2010, 06:54 PM
PacerSS's Avatar
Yeah we'll see how "excellent" it will be when I start trying to tune it lol
Old 08-25-2010, 07:29 PM
Taz is offline
Can't wait to see the results!
Old 08-25-2010, 09:00 PM
Montelicious's Avatar
Sounds exciting!
Old 08-25-2010, 09:35 PM
what exactly does e85 do besides being able to use ethanol? high compression rate or something for more power?
Old 08-25-2010, 09:44 PM
PacerSS's Avatar
From what I understand it has a slower burn front and lower ignition point which allows for more timing and higher compression. With the L36 bottom end the compression is raised over stock L67 compression. This will allow for more power. It also burns cooler which will result in less KR and pre-detonation.
Old 08-25-2010, 09:47 PM
^exactly. To be less technical and leave some stuff out in the process: It's higher octane than traditional unleaded gasoline and let's you run a ton more timing, boost, and compression compared to 93 octane gasoline.
Old 08-25-2010, 10:03 PM
zipper's Avatar
And don't forget also that being that it's E85, it's good for cleaning out the engine. Some people have taken their heads off of their engines after running E85 and they look brand new. No carbon build up or anything. It burns clean and is basically somewhere around 100 octane fuel, while being traditionally cheaper then regular unleaded at the same time. It's good stuff.
Old 08-25-2010, 10:17 PM
PacerSS's Avatar
Anyone else get a half-chub just talking about it? lol
Cowboy6622
12-21-2011 04:25 PM
mousehousemoparman
12-19-2011 03:59 PM
raceman946
07-19-2009 11:41 AM
03-17-2009 07:10 PM
thomasnchy
04-20-2008 05:03 PM
Quick Reply: 11 sec Monte almost ready
