100+
Old Mar 18, 2009 | 11:16 PM
Blown04SS's Avatar
Default 100+
so i was on my way home from work tonight and had 3 lanes of empty highway in front of me, i decided to do a little high speed run...and noticed that my car REALLY gives up accelerating when i get above 105 or so, i could actually feel the car slow its acceleration, i kept it to the floor for a long time, and just barely got to about 112
is this a common thing? or is there something (else) wrong with my car?
Old Mar 19, 2009 | 12:04 AM
kweef's Avatar
if i remember right 105 is when it shifts into 4th (overdrive) or maybe thats just my car...i cant remember what stock is anymore so that could b a factor. also ur fuel shutoff and rev limiter prolly cut u off
Old Mar 19, 2009 | 01:37 AM
thewhitestcarlouknow's Avatar
it is probably your governor shutting you down but i didnt think it would be around 112 that is what it is on most of the malibus but from what i know the ss and supercharged should be around 128 without the limiter removed
Old Mar 19, 2009 | 06:47 AM
aussiek2000's Avatar
mine does the same thing. As soon as I get around 105 the rpms drop to around 3500 and it slowly creeps up to 110.
Old Mar 19, 2009 | 06:52 AM
jaws2008's Avatar
GOT SPL
mine stays in it fast just like everywhere else till about 118 or so then it about stays there. it still accels some especially if you are going down hill some, but if its flats its cuts out at about 118
Old Mar 19, 2009 | 08:52 AM
RickAKATed10's Avatar
Photobucket
Wow... That's a really low governor. My Stratus was set around 134.
Old Mar 19, 2009 | 10:05 AM
wiz kidd's Avatar
no thats probably about right, it can only accelerate for so long, i dont remember what my monte did, i know my magnum goes quiete a bit further than that before it slows down...but it does the same thing...once you hit a certain speed the acceleration rate drops off
Old Mar 19, 2009 | 11:58 AM
rj's Avatar
rj
What, no pics or at least a video?
Old Mar 20, 2009 | 12:59 AM
Blown04SS's Avatar
i could try to take one with my cell phone if i get another open stretch of highway, but i wouldnt know how to post it
and its not the gov, rev limiter, or fuel cut-off, it still accelerates, just MUCH slower after it slowed i made it to about 112 and it was still accelerating...i just let off cuz i was coming up on some cars
i used to hit the gov in my grand prix all the time, it was at 107 and thats not at all what the monte is doing, the rpms dont drop, the exhaust note doesnt change, its just like it runs out of power
Old Mar 20, 2009 | 06:28 AM
Arrow Ultimate Power Upgrade ?
Hi `Jon,
If your cat isn't clogged, and all your sensors are `ok
and you are in tune. I would have your auto computer reflashed, or look into upgrades like below.
Keep us updated. Good Luck from `Space
THE ULTIMATE POWER UPGRADE
Unleash ALL of your vehicle's potential with the best tuning tool available in the world
Automotive Performance TuningTHE ALL NEW UNICHIP Q CHIP!
Programmable Piggyback ECU Computer
TESTED PERFORMANCEThe Unichip's development for every vehicle involves demanding testing on the dyno, as well as in the field in a variety of environmental conditions and elevations
UP TO 30% MORE POWERThe Unichip releases more power from your engine, taking advantage of what stock and aftermarket components leave behind
SMOOTHER PERFORMANCEThe Unichip's software is crafted to your specific engine, adding power where available and smoothing out the RPM curve for more power across the entire band
PLUG N' PLAY CONNECTORSThe Unichip uses custom-manufactured OEM connectors to connect the piggyback processor with the factory OEM computer
INVISIBLE INSTALLATIONThe Unichip installs leaving absolutely NO FOOTPRINT - meaning its completely invisible to factory diagnostic tools
MAXIMIZE THE POTENTIALThe Unichip is engineered to maximise the potential of aftermarket add-ons such as Cold Air Intakes, Turbos, Superchargers or Exhaust Systems
http://www.unichip.us/index.asp?gclid=CIqcr9GxsZkCFSQMDQodV3ew7A
