06 headlight chrome
Old Jan 5, 2007 | 01:45 PM
Laserblue06ss's Avatar
Default 06 headlight chrome
Has anyone else had a problem with the chrome in the headlamps turning grey on their 2006 Monte Carlo? Mine started after a few thousand miles.I just had new ones put in under warranty last week.The car just turned 8000 miles.the dealer said the heat buildup most likely is causing it.By the way,don't wait until the warranty runs out,new units list for $259 each.
Old Jan 5, 2007 | 01:54 PM
benhillzone3's Avatar
Default RE: 06 headlight chrome
damn i guess chevy didnt think about the cgrome plating turning cause if it was real chrome i dont think that heat would make it turn like that
Old Jan 5, 2007 | 01:56 PM
wiz kidd's Avatar
must be a defect in the headlights to allow moister to get into them to cause the chrome to corode
Old Jan 5, 2007 | 02:09 PM
06BlackSS's Avatar
No issues with mine yet, but it does sit in a heated garage. Will have to keep an eye on them!
Old Jan 5, 2007 | 02:29 PM
wiz kidd's Avatar
i think this issue may be for people that live up north with the crappy weather
Old Jan 5, 2007 | 03:35 PM
rj's Avatar
rj
How far up north?
As of right now no problems with mine.
Wonder if a small drain hole drilled in the bottom of the headlight buckets would relieve this problem? It would let themoisture wick out.
Old Jan 5, 2007 | 03:47 PM
I have never seen any moisture inside the lights.The part that turned grey was the flat ledge above the low beams.You didn't really notice it in the sun because of the glare,but in the garage you could really see it.
Old Jan 5, 2007 | 04:22 PM
06MonteSS's Avatar
hmmm.. I'll have to check mine out... I've got 23k miles but haven't really looked at the lights for that...
I do know that I don't get any moisture in them though... and I've already been through 1 winter with the car...
Old Jan 5, 2007 | 05:10 PM
cain45's Avatar
I'm so glad you brought that up. I thought it was just a visual "anomalie" that I was witnessing but mine do it too. No water in them just some "greying" on the upper parts of the lights.
Old Jan 5, 2007 | 07:54 PM
I sometimes get moisture in my right tail light lens, but I guess I just ignore it, but I have an 03
