'04 Monte With 90K Starting Harsh Shifting??
Old May 24, 2010 | 05:58 PM
RickCoMatic's Avatar
Default '04 Monte With 90K Starting Harsh Shifting??
My Monte is right at 90,000 miles.
Recently, I have been "Feeling" the tranny shift.
I don't know if it's supposed to be shifting like this or not.
I'm not sure how to describe it.
It's still smooth and automatic; but the actual moment when the shift is made seems to be pronounced rather than a dissolve from Second into Third.
Not very often. But, sometimes, ... it "Bumps" to get-going at a light.
Or, when I back-out of the driveway and shift from Reverse into Drive.
I recently had my Transmission Fluid changed. I looked at the Dipstick and its right up-there on the Top of the crosshatch.
Happy Summer to the Monte Forum Members,
RickCoMatic
Old May 24, 2010 | 09:07 PM
Enzo354's Avatar
STILL SLOW
Im not sure, hopefully your tranny is good.
Old May 25, 2010 | 01:27 AM
Sliver's Avatar
Does the shifting get worse when the engine/tranny have warmed up?
Old May 25, 2010 | 02:30 AM
seawolf18's Avatar
sounds like the trans pressure solenoid. Pull the codes, and see if one for long shift is in there. That code does not set the SES light off.
Old May 25, 2010 | 11:36 AM
zipper's Avatar
Somebody snuck a shift kit into the trans
Old May 26, 2010 | 12:20 PM
^^^ what? lol
Old May 26, 2010 | 12:27 PM
lucian*91's Avatar
i know if it has a small slip and you put fresh tranny fluid in it it will make it worse then actually helping the problem.... hehe reminds me of when someone wanted there filter checked because they said it seemed clogged. well once we dropped the pan a little bit we sure noticed it had nothing to do with the filter.. that fluid was pitch black.... and stunk like crazy
Old May 26, 2010 | 04:43 PM
STL_CHeVY_RiDeR's Avatar
thats what mine was doing at 90k......
i ended up havin it rebuilt.... shop showed me the fluid.... black and thick.... said i was grinding metal on metal.....
the worse use of $1900 ever
Old May 26, 2010 | 08:53 PM
lucian*91's Avatar
this happens pretty comonly when you accelerate really hard all the time and quickly release the pedal. if its released when it is about to shift. shifting, or just shifted. its really hard on it dropping all those rpms. i screwed up my impala and it didnt like to go from 3rd to 4th gear really good. i since accelerate hard and slowly easy off the pedal letting the rpm drop slower
rpd709
17
Nov 14, 2010 10:54 PM
