Repair Guide: List of Common Monte Carlo Problems and Solutions
Old Jun 25, 2012 | 08:42 AM
  #41
Road Noise, and ABS/Trac Off Lights
Some people want the money from the work.
Old Jul 2, 2012 | 05:34 AM
  #42
Manuel Jblaze Garcia's Avatar
Whenever the problem is a hot start-up, unplug the MAF sensor and see if it starts up then.
It might be that is starting to go.
Thanks for the advice im new to the forum and I have the same exact issue where is the maf sensor located ? Thanks again.
Old Jul 2, 2012 | 08:44 AM
  #43
Depends on your engine.
If you have the 3800 it is on the TB (the flat sensor closest to the TB opening)
If you have a 3400/3500 it is in the intake tube, that square halfway down.
Old Jul 26, 2012 | 09:43 PM
  #44
05MonteLS's Avatar
You forgot a few(for 6th Gens at least)..
Problem: Water shows up on headliner after rain, leaks around A-pillars, and pools on the floor. Caused by plugged-up sunroof drains.
Solution- Unplug drains with compressed air and retest drains.
Or-
Problem: Lights in Instrument Cluster/Radio/HVAC panel burn out with age. Lamps are "non-removable" due to crappy design..
Temporary solutions: Replace whole cluster ($$$$), solder in new light bulbs
Permanent solutions: Solder in LEDs or send cluster into BBEngineering to get LEDs installed.
I'm sure there's more, but that's all I can think of for now..
Old Jul 28, 2012 | 02:45 PM
  #45
Mike Ancona's Avatar
Default 2001 Monte Carlo electrical issues
2001 Monte Carlo,sometimes engine wont crank,but have full power to everything else,and also turn signals will not work on occasion,do you thing I have a bad ground connection or bad ignition switch,are these two connected or are they separate issues!
Thanks Mike
Old Jul 30, 2012 | 08:31 AM
  #46
I would check into the starter if it intermittently has problems starting.
Turn signals, when they don't work press your hazard switch on and off. Could be a problem at that switch.
Old Jul 31, 2012 | 09:10 PM
  #47
MySS's Avatar
my car has alot of these problems, just got it today(85 SS), hazard lights work but when i turn blinker on the lights stay solid and dont flash, it was bruning oil on passenger side under the hood (thinks its valve cover gasket), and the only gauges that work are the RPMs and the battery(not sure what the cause of this is)
Old Sep 1, 2012 | 08:03 AM
  #48
coyne's Avatar
Can you help me I have a 2003 Monte Carlo, fog lights are dim, message ctr says I have a high beam out which is untrue and my dashboard instrument lights are always on even when the switch is in the off position.
Old Sep 10, 2012 | 11:08 PM
  #49
robz's Avatar
Smile Exactly what I've been looking for
Or-
I've been wondering why on heavy rain days my passenger side headliner is wet and runs down and pools on the floor. I even see the water streak on the fuse door, which would really ruin my day. I'm going to give this solution a try. Thanks.
Old Sep 13, 2012 | 03:41 PM
  #50
crankshaft20's Avatar
i just got a 2001 ss it is doing the abs light thing but it also makes a buzzing sound when the light turns off like pump turning on what is it
