Road Noise, and ABS/Trac Off Lights
Some people want the money from the work. |
(Post 464323)
Whenever the problem is a hot start-up, unplug the MAF sensor and see if it starts up then.
It might be that is starting to go. |
Depends on your engine.
If you have the 3800 it is on the TB (the flat sensor closest to the TB opening) If you have a 3400/3500 it is in the intake tube, that square halfway down. |
You forgot a few(for 6th Gens at least)..
Problem: Water shows up on headliner after rain, leaks around A-pillars, and pools on the floor. Caused by plugged-up sunroof drains. Solution- Unplug drains with compressed air and retest drains. Or- Problem: Lights in Instrument Cluster/Radio/HVAC panel burn out with age. Lamps are "non-removable" due to crappy design.. Temporary solutions: Replace whole cluster ($$$$), solder in new light bulbs Permanent solutions: Solder in LEDs or send cluster into BBEngineering to get LEDs installed. I'm sure there's more, but that's all I can think of for now.. |
2001 Monte Carlo electrical issues
2001 Monte Carlo,sometimes engine wont crank,but have full power to everything else,and also turn signals will not work on occasion,do you thing I have a bad ground connection or bad ignition switch,are these two connected or are they separate issues!
Thanks Mike |
I would check into the starter if it intermittently has problems starting.
Turn signals, when they don't work press your hazard switch on and off. Could be a problem at that switch. |
my car has alot of these problems, just got it today(85 SS), hazard lights work but when i turn blinker on the lights stay solid and dont flash, it was bruning oil on passenger side under the hood (thinks its valve cover gasket), and the only gauges that work are the RPMs and the battery(not sure what the cause of this is)
Can you help me I have a 2003 Monte Carlo, fog lights are dim, message ctr says I have a high beam out which is untrue and my dashboard instrument lights are always on even when the switch is in the off position.
Exactly what I've been looking for
Originally Posted by 05MonteLS
(Post 481434)
i just got a 2001 ss it is doing the abs light thing but it also makes a buzzing sound when the light turns off like pump turning on what is it
