Repair Guide: List of Common Monte Carlo Problems and Solutions
Im curious in regards to loseing antifreeze.....i have a 99 Z 34 monte with the 3.8 series II....I replaced upper intake at around 100,000 miles...i now have 154,000 on it and now im loseing antifreeze with no apparent leaks, nothing out of the exhaust, or on the floor(garage kept).....I dont smell any under the hood or see any signs of an "open"leak, or in the car..... The idiot light comes on and the resevoir is low....i fill it back up...and a few weeks go by(3 to 4) and its low again....IM STUMPED!
literally ! I even pressure tested the system and no leak down what so ever......any help would be greatly appreciated ..Thanks !
Hey. I have an 2000 SS. With 160 miles. And every so often. A few times a week. My transmission starts potting into gear. Usually after i quick acceleration. But sometimes just during normal dfiving. No idea why. Anybody else out there have the similar problem? Abd the fluid is pretty old. Should i chnane and put in a condioner or.... Any imput would be hepful
thanks
thanks
Problem: Pulsing/shaking under braking
Cause: Warped rotors.
Solution: Replace with a quality aftermarket rotor and this problem should go away. After going through several sets of OEM rotors, I switched to Centric and haven't warped a set since.
Prevention: avoid getting rotors wet while hot, avoid hard braking and then holding the pads on the rotors
Is an issue I have I'm looking into getting Centric since that's obviously what was suggested, any specific type you suggest? I have an 06 Monte SS the only mods I'm going to have is Thrush muffler and CAI maybe a res delete. I don't usually do hard breaking... on occasion... (Windsor drivers SUCK!)
Hey Chibz. Love the write up man. If you don't mind I wanted to add two more, and I think its a common problem on the Monte's of the 6th gen. Driver's side heated seat malfunction and code P1811 max adapt long shift transmission solenoid fault. Thanks again for the information though.
