How To: Run Wires to Install Amp
Here is a walk through video on how to run wires for an amp, or anything else that you need, ran through to the trunk.
Sorry the video is not the best, my settings were messed up on my phone and I was having trouble with my back, but you get the basic idea of the easiest way to run wires through our Montes. Should be the same for the 06/07 Monte's also. |
i ran a wire through the grommet and boot and had a 4-5 inch section burn up. i havent had a chance to see what happened, but im assuming it was resting on an exhaust pipe or something.
Originally Posted by 02LS
(Post 313407)
(Post 313407)
I did a photo write up for another forum, figured I could copy the thread here.
Due to the recent spate of questions regarding getting wires across the firewall and my need to run a power wire, I thought it would be nice to take some pictures and get something more in depth than the ImpalaHQ archive. Here is a the part that you need to remove from the grommet in order to run the part It's pretty hefty and mine was glued in place, so it took some work with a large flat head screwdriver to pop it out. http://i287.photobucket.com/albums/l...forGrommet.jpg Here is what it looks like without the plug. http://i287.photobucket.com/albums/l...lugremoved.jpg After getting it out you want to take a small screwdriver and puncture the rubber accordian from the inside of the car. I turned the steering wheel all the way to the right in order to get better access to the grommet from under the car without using a jack. Here is my screwdriver through the grommet. If you create a small enough hole, the rubber will 'seal' against the wire. http://i287.photobucket.com/albums/l...ughgrommet.jpg I pushed the power wire through from the outside and pulled about 4 feet through the grommet and into the engine bay like this and then fished for it from above with a hanger. http://i287.photobucket.com/albums/l...ughgrommet.jpg To get to the battery, I brought it up around the back of the coolant overflow bottle like this. http://i287.photobucket.com/albums/l...ndcoolant2.jpg I then routed it through the engine bay and covered it with some wire loom (found at Radioshack for about 5 dollars) and used some zip ties. The pink zip ties are on the wire I ran through the grommet. http://i287.photobucket.com/albums/l...nalproduct.jpg The inside of the car should look like this (keep in mind I didn't replace the plug for this picture, but you will want to put the plug back into place. http://i287.photobucket.com/albums/l...fyG/inside.jpg Hopefully, this will make it more clear as to what is involved in getting a wire across the grommet in the passenger foot well. One of the easiest places to ground your amplfier is under one of the strut mount nuts. Remove some paint around the bolt as shown here: http://img508.imageshack.us/img508/1590/cimg0676.jpg Then slip the ring terminal over the stud and reattach the nut. http://img718.imageshack.us/img718/297/cimg0683x.jpg |
