Thanks for the part #. Spent a while yesterday trying to find the part #
Where do I order the whole kit at? I'd like to get it for my LS before i do my L67 swap.
GREAT THREAD! But if I understand this correctly, this guy bought this package from gmpartsdirect? If he did, they dont sell them painted anymore. And an unpainted package is $1041.85 is that a reasonable price or does anyone know a better method?
Originally Posted by guzzimane
(Post 618815)
does the complete kit come with all the hardware and the side ground effects? How much was shipping??
this might seam like a really stupid question, but any tips on how to remove these, the rear and side skirts?
The first thing that is done is to put several layers of masking tape on the rocker below the Monte Carlo emblem. This is to protect the paint as you push up and release the original plastic lower rocker. You also want to put several layers of masking tape on the front fender ahaed of the door. You won't need to protect the door since it will be open as you work. You will need to use a flat bladed screwdriver to release the clips that hold the rocker to the car. These are located under the car. As you release the clip, pull the rocker toward you so that they release. There are 8 of these on each side of the car. The Rocker off the car Once you release the gray clips on the bottom of the rocker, open the door, and start at the back of the car, and pull the rocker out from the bottom while pushing up on it. This will release the clips that are behind the rocker. This takes some force to get the first couple to release. But once the first one does the rest come out easy. With the rocker off, remove the clips that will be left in the car. You get all new ones in the kit so don’t worry about the ones that break. Here are the new clips Here is a shot of the side GFX with clips on it |
Nice detailed write up TMoney!
Originally Posted by GTHSS
(Post 636742)
Lots Of Help
Your install steps was very helpful though I have not started, but im lost as far as the self stick vinyl template, where can I obtain that from, or is there an alternate way around it.
