Mod Guide: How to install HID Headlights for 2000-2005 Monte Carlo
hooooold up. you aren't 100% correct on that statement! in 2004 and 2005 GM switched the Impala and Monte Carlo's DRLs over to the LOW BEAM side. Why? i'm not sure. But i know that's a true fact because my '05 monte has DRLs on the low beams. and one thing i always notice with the supercharged Impala's and Monte's is that they always have the DRLs on the low beam side also and they were made in 04 and 05 only. so 2000-2003 Impala/ Monte Carlo has DRL high beams and 2004-2005 Impala/ Monte Carlo has DRL on low beam.
So chibiblacksheep and ramairetransam are both correct lol.
Aaron
OH yeah, see Shutter Island if you get the chance, good movie
well i just kinda thought it was that way for the 04-05 because of the other little minor changes they made like the HVAC system with the modes and maybe some other little things. but i know 100% it's low beam DRL for 05 lol. but i could have sworn that i've been in a 04 with low beam DRL's also.
the hid will be more brighter and no the headlights will not always be on. no switch is need. one ground wire and one power to the battery. the other end of the plug go to headlight plug end. i have to go look at my setup again to see how i had it plug in. forgot how lol. here's the link to the harness. the company also sell parts that you can build your own projector halo. check out their web site.
http://shop.3bspecialties.com/HID-Re...ID-Harness.htm
Is there a delay switching from High to low beams? I have read that the relay harness causes a 3 second delay because the HIDs have to restart? My other question was: When you install the harness, can't you just connect the ground to the negative battery terminal? Or do you have to ground it to the body of the car or some sort of metal on the car? I have not had any problems with mine on the stock wiring but I don't wanna burn the stock wiring either.
when turn on the car the hid slowly warm up in other word the hid will slowly dim at start up and brighten up. the harness have nothing to do with that i know of. i know it does the same thing even without the harness. on the harness, there's a ground wire that you have to ground to the body of the car. everything else is plug and play. try to get the 35 watt hid. i would not get 55 watts cuz in the long run will see some warp/melt on the headlight housing.
I run my 8000k on my lows and never even use my high beams at all. I know some people on here do both the lows and the highs but I have also heard that putting them in the highs can cause problems because its not good for them to be going on and off rapidly.
On my 2002 Monte the DRL's are the high beam. I have the HID's installed on the low beam with no problems. As suggested earlier in this post I just ordered the HID harness to connect to the battery to get better performance.
Here are some ideas:
HID Kit:
http://cgi.ebay.com/ebaymotors/HID-K...item2a04ac1064
Harness:
http://cgi.ebay.com/ebaymotors/9006-...Q5fAccessories
