Mod Guide: How-to: 5th gen FWI
Old Jun 29, 2009 | 10:50 AM
zzapultimate's Avatar
So I bought my 3'' pvp piping and two 3'' silicone couplers only to realize that the 3'' measurement measure the ID of both pieces. So there is no way I am going to get my couplers to stretch over the pvc piping which is 3.5'' OD.
EDIT: Never mind, I beveled the edge of the piping and applied a little grease and i was able to stretch the coupling over.
Old Jun 22, 2010 | 11:12 AM
sillykumquat's Avatar
What exactly have you gained? What exactly is the difference between the intakes? I have read this a few times, and i just cant seem to figure out whats going on.
Old Jun 22, 2010 | 11:36 AM
The Popcorn King's Avatar
He is getting colder, denser air from OUTSIDE the engine compartment. The denser the air, the better your performance. If you get those EBAY intakes, your getting hat air from the radiator. Robbing performance from your engine.
Old Jun 23, 2010 | 02:30 AM
How does the intake get the air from the outside? Looks like there is already a stock intake from the outside, am i right?
Old Jun 23, 2010 | 08:14 AM
Stock intake is extremely restrictive, this is giving him loads more air, and it's still that delicious cold cold air
More air = More power
Old Jun 23, 2010 | 11:58 AM
mrl390's Avatar
The stock airbox box is pretty restrictive. Compared to a FWI the stock air box flows alot less air. The FWI flows better because of the larger diameter of the pipe. Not only that, but the filter itself is separated from the engine compartment by the inner fender. The filter sits inside the fender, drawing cool air that flows around the headlight and up from the front bumper.
The only part of the stock intake I used was the flex tubing from the throttle body to the MAF sensor. Everything else is 3" piping and a cone filter.
Old Oct 23, 2010 | 02:27 PM
digital_kid0101's Avatar
Wheres the windshield washer fluid tank at now?
Old Oct 23, 2010 | 02:37 PM
mrl390's Avatar
I used an astro van washer bottle and pump. I mounted it under the black plastic filler between the bumper cover and the rad support. Then I lengthened the wiring to the old pump and wired it to the new pump and lengthened the fluid hose. Heres a photo of where it sits now.
Old Oct 27, 2010 | 06:40 PM
Beautiful! I love how you did it! and is the new air filter secluded from the wheel well so it doesnt get water + dirt + snow in it?
Old Oct 31, 2012 | 03:02 AM
Aeyame's Avatar
Wow! This sounds awesome! I've never heard of it before, but it's definitely something I want to do to mine.
Ashley.Marie
Apr 24, 2011 10:17 PM
88ss408
Apr 1, 2010 08:29 PM
YamahaR14
Apr 21, 2008 06:53 PM
