Repair Guide: Finally!!! Gauge Cluster Problem Fix!! - Stepper Motor
Old Jan 8, 2011 | 11:30 PM
  #41
Originally Posted by Paul Horst
Thank you first for the info. We have a 2004 Monte Carlo SS with 50,000 miles on odometer. The tachometer started acting up about 3 months ago. It wasn't until the temp gauge and oil pressure gauge started going wacko that I found this forum. I ordered stepper motors and got them and was planning on doing the repair tomorrow. My wife came home today from a funeral with a speeding ticket for 20 over on freeway. Do we bite the bullet and pay $175 or will taking it to speedometer shop to verify defect help us save some money?
I think for a ticket they will tell you since you knew about it before that you should have taken care of it before and wont help you, but that's Just what I heard.
Old Jan 9, 2011 | 12:09 AM
  #42
MillerMonteSS's Avatar
2010 Monte Of The Year
It will be pretty hard to convince a judge that she didn't know she was speeding. 20+ over the limit is a "reckless operation" charge in a lot of states. Good luck.
Old Jan 10, 2011 | 04:51 PM
  #43
Is this the right ones for the job?
http://cgi.ebay.com/ebaymotors/6-03-...#ht_1910wt_907
also what would need to be used for leds?
Old Jan 16, 2011 | 10:24 PM
  #44
Paul Horst's Avatar
I took wifes Monte to speedometer shop on Monday. I explained the problem, and of course they know all about it. They gave me an inspection report indicating that the speedometer was defective and could show speeds from 0-120 mph at anytime, and a written estimate for repair of $ 300. I asked if he thought the speedometer being defective is worth bringing up. He said I'm not the first one to find out the way wife did, and it was worth a try, but talk with attorney about it. I did that next day. Attorney's first question was how many tickets has wife had. She has had zero her whole life driving. He was very optimistic because of that. We decided to go to court and give it a go. He said to be straight forward and request a "deferred finding" and basically she would have to not get another ticket in 12 months, and at that time the record of ticket is expunged. I'll get back here and let you know how it works out.
Old Jan 29, 2011 | 09:39 AM
  #45
tj4ndirish's Avatar
Should the battery be disconnected when doing this? Any other advice before I start?
Thanks.
Old Jan 29, 2011 | 10:45 AM
  #46
Thanks.
It doesn't have to be but if Your Not really sure what your doing then you should probably unhooking It just in case
Old Feb 4, 2011 | 10:24 AM
  #47
tj4ndirish's Avatar
So, Saturday I finally got my lazy butt out to change the steppor motors on my cluster. Hardest part was the desoldering. Everything back together and take it on a test run........everything works fine. Monday works as it should. Tuesday, not paying attention because for 2 days worked fine. Come home after work Tuesday, look down and I'm going 120 in a 35. WTF................Has anyone else had this problem after "fixing" the problem?
Old Mar 14, 2011 | 08:10 PM
  #48
Joelfke's Avatar
any way to test the operation of the motors while the cluster is still out?
Old Mar 15, 2011 | 05:06 AM
  #49
Paul Horst's Avatar
A speedometer shop probably could. When I did mine, I plugged the cluster back in with the front cover off and turned key to the "on" position to check that all gauges zeroed up properly. Tach was showing 200 rpm. Turn key off and wait for needle to come to "at rest" position, and turn the needle counter clockwise to adjust for that. Then a test drive before putting dash panel back on.
Old Mar 27, 2011 | 12:08 AM
  #50
ndgrown's Avatar
would a bad stepper motor cause 2 gauges to act up on the same motor
