Info: 6th Gen Wiring Diagrams and Connector Layouts
Old Apr 6, 2011 | 11:05 AM
02LS's Avatar
Default 6th Gen Wiring Diagrams and Connector Layouts
Audio Amplifier C1
Connector Part Information: 12110088
24-Way F Micro-Pack 100 Series (Grey)
Pin Wire Color Circuit Number Function
A1 Black 1051 Ground
A2 - - Not Used
A3 Orange 2640 Battery Positive Voltage
A4-A8 - - Not Used
A9 Light Blue 115 Right Rear Speaker Output (-)
A10 Yellow 116 Left Rear Speaker Output (-)
A11 Dark Green 117 Right Front Speaker Output (-)
A12 Grey 118 Left Front Speaker Output (-)
B1 Black 1051 Ground
B2 - - Not Used
B3 Orange 2640 Battery Positive Voltage
B4 - - Not Used
B5 White 1487 Antenna Enable Signal
B6-B8 - - Not Used
B9 Dark Blue 46 Right Rear Speaker Output (+)
B10 Brown 199 Left Rear Speaker Output (+)
B11 Light Green 200 Right Front Speaker Output (+
B12 Tan 201 Left Front Speaker Output (+)
Audio Amplifier C2
Connector Part Information: 12064799
12-Way F Micro-Pack 100 Series (Black)
A Purple 1952 Right Front Tweeter Speaker Output (-)
B Yellow 1956 Left Front Tweeter Speaker Output (-)
C Red 1955 Right Rear Speaker Output (-)
D White 1959 Left Rear Speaker Output (-)
E Light Blue/Black 315 Right Front Speaker Output (-)
F Light Green/Black 1794 Left Front Speaker Output (-)
G Dark Blue/White 346 Left Front Speaker Output (+)
H Dark Green 1795 Right Front Speaker Output (-)
J Tan 1859 Left Rear Speaker Output (+)
K Tan 1855 Right Rear Speaker Output (+)
L Black 1856 Left Front Tweeter Speaker Output (+)
M Light Green 1852 Right Front Tweeter Speaker Output (+)
Radio C1
A1 Orange 1044 Radio Class 2 Serial Data
A2?? Yellow 12 Volt (+) Switched
A6 Pink 314 Radio On Signal (w/o 9C1/9C3/9C6)
A7 Dark Blue 1796 Steering Wheel Controls Signal (w/o 9C1/9C3/9C6)
A8 Tan 201 Left Front Speaker Output (+)
A9 Gray 118 Left Front Speaker Output (-)
A10 Light Blue 115 Right Rear Speaker Output (-)
A11 Dark Blue 46 Right Rear Speaker Output (+)
A12 Black 1051 Ground
B1 Orange 2640 Battery Positive Voltage
B3 White 1487 Antenna Enable Signal
B4 Gray 8 Illumination
B5 Black 1050 Ground
B6 Purple 2232 Amplifier Signal (Monte Carlo)
B8 Brown 199 Left Rear Speaker Output (+)
B9 Yellow 116 Left Rear Speaker Output (-)
B10 Dark Green 117 Right Front Speaker Output (-)
B11 Light Green 200 Right Front Speaker Output (+)
Radio C2
24-Way F Micro-Pack 100 Series (Black)
L Black/White 372 Remote Radio Audio Output (-)
M Dark Green/White 368 Remote Radio Right Audio Signal
Radio Antenna Module
Connector Part Information: 15359292
2-Way F 58 Series (Black)
A White 1487 Antenna Enable Signal
B Dark Green 1927 Radio Antenna/Rear Window Defog Control Module Supply Voltage
Speaker Left Door
Connector Part Information: 12186567
4-Way F Metri-Pack 150 Series, Sealed (Black)
A Grey 118 Left Front Speaker Output (-)
B Tan 201 Left Front Speaker Output (+)
C Yellow 1956 Left Front Tweeter Speaker Output (-)
D Black 1856 Left Front Tweeter Speaker Output (+)
Speaker Right Door
A Dark Green 117 Right Front Speaker Output (-)
B Light Green 200 Right Front Speaker Output (+)
C Purple 1952 Right Front Tweeter Speaker Output (-)
D Light Green 1852 Right Front Tweeter Speaker Output (+)
Speaker Left Right
Connector Part Information: 12052832
2-Way F Metri-Pack 150 Series, Sealed (Black)
A Tan 1859 Left Rear Speaker Output (+) (UQ3)
Brown 199 Left Rear Speaker Output (+) (UW6/U62)
B White 1959 Left Rear Speaker Output (-) (UQ3)
Yellow 116 Left Rear Speaker Output (-) (UW6/U62)
Alarm Wiring Diagram
Ignition Harness
Red Battery Constant 12v (+)
Yellow Starter (+)
Pink Ignition (+)
Green Second Ignition (+)
Orange Accessory (+)
Body Control Module
Above Brake Pedal - 3 Plugs That Face Firewall
A2 White Parking Light (-) In Pink Plug
Orange/Black Power Door Lock (-) In Gray 24-Pin Plug
Negative through 480 ohm resistor (lock). Straight negative (unlock)
Door Trigger (+) In Gray 16-Pin Plug
Blue Door Trigger (-) In Gray 16-Pin Plug (Driver Door)
Blue/White Door Trigger (-) In Gray 16-Pin Plug (Passenger Door)
Blue Domelight Supervision (-) In Gray 16-Pin Plug
Misc
Black Trunk Release (-) At Trunk Release Switch
Black Horn (-) At Steering Column Harness
White Tachometer (-) At Ignition Module
White Brake Light (+) At Switch Above Brake Pedal
Light Green Factory Alarm Disarm (-)
Yellow Factory Anti-Theft (+) At Top Of Ignition Switch Tumbler
Black Factory Anti-Theft (-) At Top Of Ignition Switch Tumbler
Old Apr 6, 2011 | 03:05 PM
Milhouse's Avatar
Looks like some valuable info in there, thanks for sharing!
Old Oct 3, 2012 | 07:44 PM
LauderdaleMonte's Avatar
i was just wondering if there was supposed to be a diagram or something i am missing from here ? great info esp since i really dont know auto electric at all and am learning, any diagrams would be appreciated
Old Oct 4, 2012 | 07:46 AM
03SSLE's Avatar
The Haynes repair manual (about $15) for our cars has several wiring diagrams in it including the audio system.
Old Oct 15, 2012 | 10:12 AM
im getting one this week. I have my car in the shop since i dont have the tools or space to rebuild my engine. I still have much more to do though so the manual will be helpful.
Old Jul 8, 2015 | 11:55 AM
karl_t's Avatar
Are there any pictures of the three wire connector that goes to the top of the ignition switch for the anti-theft. My friend unplugged them and doesn't remember in which oeder they go back in?
Old Feb 19, 2017 | 08:16 PM
tfunk002's Avatar
the book is 25:00 bucks
Old Oct 19, 2018 | 02:40 PM
dd850's Avatar
i need the wiring diagram for the drivers' side window switch for a '95 Z34. My switch is a "1st design" and all the switches i could buy are "2nd design" so I need to changes a few things to make the new one work.
drivernumber3
Aug 13, 2017 10:48 AM
MJClemm
Mar 6, 2014 04:34 PM
GqAmbitions
Mar 25, 2012 04:51 PM
thumpingetocar06
Feb 20, 2010 12:40 PM
aussiek2000
Jul 16, 2008 07:06 AM
