6th Gen Wiring Diagrams and Connector Layouts
Audio Amplifier C1
Connector Part Information: 12110088 24-Way F Micro-Pack 100 Series (Grey) Pin Wire Color Circuit Number Function A1 Black 1051 Ground A2 - - Not Used A3 Orange 2640 Battery Positive Voltage A4-A8 - - Not Used A9 Light Blue 115 Right Rear Speaker Output (-) A10 Yellow 116 Left Rear Speaker Output (-) A11 Dark Green 117 Right Front Speaker Output (-) A12 Grey 118 Left Front Speaker Output (-) B1 Black 1051 Ground B2 - - Not Used B3 Orange 2640 Battery Positive Voltage B4 - - Not Used B5 White 1487 Antenna Enable Signal B6-B8 - - Not Used B9 Dark Blue 46 Right Rear Speaker Output (+) B10 Brown 199 Left Rear Speaker Output (+) B11 Light Green 200 Right Front Speaker Output (+ B12 Tan 201 Left Front Speaker Output (+) Audio Amplifier C2 Connector Part Information: 12064799 12-Way F Micro-Pack 100 Series (Black) Pin Wire Color Circuit Number Function A Purple 1952 Right Front Tweeter Speaker Output (-) B Yellow 1956 Left Front Tweeter Speaker Output (-) C Red 1955 Right Rear Speaker Output (-) D White 1959 Left Rear Speaker Output (-) E Light Blue/Black 315 Right Front Speaker Output (-) F Light Green/Black 1794 Left Front Speaker Output (-) G Dark Blue/White 346 Left Front Speaker Output (+) H Dark Green 1795 Right Front Speaker Output (-) J Tan 1859 Left Rear Speaker Output (+) K Tan 1855 Right Rear Speaker Output (+) L Black 1856 Left Front Tweeter Speaker Output (+) M Light Green 1852 Right Front Tweeter Speaker Output (+) Radio C1 Connector Part Information: 12110088 24-Way F Micro-Pack 100 Series (Grey) Pin Wire Color Circuit Number Function A1 Orange 1044 Radio Class 2 Serial Data A2?? Yellow 12 Volt (+) Switched A6 Pink 314 Radio On Signal (w/o 9C1/9C3/9C6) A7 Dark Blue 1796 Steering Wheel Controls Signal (w/o 9C1/9C3/9C6) A8 Tan 201 Left Front Speaker Output (+) A9 Gray 118 Left Front Speaker Output (-) A10 Light Blue 115 Right Rear Speaker Output (-) A11 Dark Blue 46 Right Rear Speaker Output (+) A12 Black 1051 Ground B1 Orange 2640 Battery Positive Voltage B3 White 1487 Antenna Enable Signal B4 Gray 8 Illumination B5 Black 1050 Ground B6 Purple 2232 Amplifier Signal (Monte Carlo) B8 Brown 199 Left Rear Speaker Output (+) B9 Yellow 116 Left Rear Speaker Output (-) B10 Dark Green 117 Right Front Speaker Output (-) B11 Light Green 200 Right Front Speaker Output (+) Radio C2 Connector Part Information: 12064799 24-Way F Micro-Pack 100 Series (Black) Pin Wire Color Circuit Number Function L Black/White 372 Remote Radio Audio Output (-) M Dark Green/White 368 Remote Radio Right Audio Signal Radio Antenna Module Connector Part Information: 15359292 2-Way F 58 Series (Black) Pin Wire Color Circuit Number Function A White 1487 Antenna Enable Signal B Dark Green 1927 Radio Antenna/Rear Window Defog Control Module Supply Voltage Speaker Left Door Connector Part Information: 12186567 4-Way F Metri-Pack 150 Series, Sealed (Black) Pin Wire Color Circuit Number Function A Grey 118 Left Front Speaker Output (-) B Tan 201 Left Front Speaker Output (+) C Yellow 1956 Left Front Tweeter Speaker Output (-) D Black 1856 Left Front Tweeter Speaker Output (+) Speaker Right Door Connector Part Information: 12186567 4-Way F Metri-Pack 150 Series, Sealed (Black) Pin Wire Color Circuit Number Function A Dark Green 117 Right Front Speaker Output (-) B Light Green 200 Right Front Speaker Output (+) C Purple 1952 Right Front Tweeter Speaker Output (-) D Light Green 1852 Right Front Tweeter Speaker Output (+) Speaker Left Right Connector Part Information: 12052832 2-Way F Metri-Pack 150 Series, Sealed (Black) Pin Wire Color Circuit Number Function A Tan 1859 Left Rear Speaker Output (+) (UQ3) Brown 199 Left Rear Speaker Output (+) (UW6/U62) B White 1959 Left Rear Speaker Output (-) (UQ3) Yellow 116 Left Rear Speaker Output (-) (UW6/U62) Alarm Wiring Diagram Ignition Harness Pin Wire Color Circuit Number Function Red Battery Constant 12v (+) Yellow Starter (+) Pink Ignition (+) Green Second Ignition (+) Orange Accessory (+) Body Control Module Above Brake Pedal - 3 Plugs That Face Firewall Pin Wire Color Circuit Number Function A2 White Parking Light (-) In Pink Plug Orange/Black Power Door Lock (-) In Gray 24-Pin Plug Negative through 480 ohm resistor (lock). Straight negative (unlock) Door Trigger (+) In Gray 16-Pin Plug Blue Door Trigger (-) In Gray 16-Pin Plug (Driver Door) Blue/White Door Trigger (-) In Gray 16-Pin Plug (Passenger Door) Blue Domelight Supervision (-) In Gray 16-Pin Plug Misc Pin Wire Color Circuit Number Function Black Trunk Release (-) At Trunk Release Switch Black Horn (-) At Steering Column Harness White Tachometer (-) At Ignition Module White Brake Light (+) At Switch Above Brake Pedal Light Green Factory Alarm Disarm (-) Yellow Factory Anti-Theft (+) At Top Of Ignition Switch Tumbler Black Factory Anti-Theft (-) At Top Of Ignition Switch Tumbler |
Looks like some valuable info in there, thanks for sharing!
i was just wondering if there was supposed to be a diagram or something i am missing from here ? great info esp since i really dont know auto electric at all and am learning, any diagrams would be appreciated
The Haynes repair manual (about $15) for our cars has several wiring diagrams in it including the audio system. :thumbsup:
im getting one this week. I have my car in the shop since i dont have the tools or space to rebuild my engine. I still have much more to do though so the manual will be helpful.
Are there any pictures of the three wire connector that goes to the top of the ignition switch for the anti-theft. My friend unplugged them and doesn't remember in which oeder they go back in?
Originally Posted by 03SSLE
(Post 499277)
i need the wiring diagram for the drivers' side window switch for a '95 Z34. My switch is a "1st design" and all the switches i could buy are "2nd design" so I need to changes a few things to make the new one work.
