What size torque converter bolts?
Old Oct 29, 2012 | 12:18 AM
crete's Avatar
Default What size torque converter bolts?
What wrench do I need to take off the TC from the flexplate? I am swapping out engines and am almost done with the removal.
2000 SS Monte 3.8L
thanks
Old Oct 29, 2012 | 09:15 PM
crete's Avatar
anyone?
Old Oct 29, 2012 | 10:23 PM
nitehawkjcb's Avatar
I've done it before, but I don't remember what size the 3 bolts on the flexplate are. I want to say they're 13mm but it's been a while, they could be 10mm... Just get a set of wrenches, if you're doing this much work you'll need some other ones...
Old Oct 30, 2012 | 01:00 AM
crete's Avatar
I've got a bunch but I don't have any that fit. The closest thing I had was a 3/4 but it was a little big. I'm assuming it is 19mm but I wanted to be sure. thank you though.
Old Oct 30, 2012 | 10:37 AM
Sorry man, I wish I remembered what it was... I know it sucks turning the flexplate and holding it steady to get each bolt out... Have you checked a Haynes manual?
Old Oct 30, 2012 | 11:23 PM
crete's Avatar
Yeah I have one. It didn't say from what I could tell. I'm assuming that I can put a breaker bar on the harmonic balancer to make it stay. It's a pain though.
After this I have the motor mount bolts at the bottom and the bell housing bolts and up she goes. Can't wait to get it back on the road.
Old Oct 30, 2012 | 11:24 PM
crete's Avatar
Do you remember how many motor mount bolts there are? Is it just the 2 in the frame?
Old Oct 30, 2012 | 11:47 PM
you need a shop repair manual, I checked my Haynes manual when you needed info for the torque converter and flex plate and it has no specs listed! I can understand your frustration but I can't help. I guess you have to feel around to figure it out...Totally sucks, wish I could have helped...
Old Oct 30, 2012 | 11:54 PM
maybe try rockauto.com for pics of engine mounts, it might give you an idea of what your looking at.
below is a pic from there, hope it helps. Or go to yourtube and see if there are any vids for what you're doing......
Old Oct 31, 2012 | 12:18 AM
crete's Avatar
Thanks. Yeah I'm just going to get a 19" and see if it fits.
Thanks for your help
