Originally Posted by 2004DaleJr.SS
(Post 713961)
I would need bigger injectors with a 3.0 pulley right? What size would I need, 42's?
(Post 713964)
Yes, but the size injector depends on what fuel you plan to run and what all mods you do. Injectors are pretty cheap anyways (at least compared to all the other mods you're looking at), so I'd just budget a few hundred bucks for them and pick the size you need when you firm up the rest of the list. Same with pulley size.
(Post 713969)
i might look into a stall. something in the 2600 to 2800 range.
(Post 713971)
Explain to me what this is, would you? I know WHAT it is, no idea how it works or the benefits of..
The upside is (potentially) harder launches, assuming you can put the power down. It also tends to make the car feel more peppy when driving aggressively. There are some downsides though: -More converter slip means more heat in the trans fluid. -You need to be able to put the power down as it is, or it'll just get harder to launch. -If you go too far (or get a crappy converter) it can hurt street manners. Ideally you wouldn't hardly notice at all driving around town lightly. I've seen some converters (on other applications) that feel doggy and lazy down low as they're not setup to transfer power well down there. -Can hurt gas mileage. |
