Weird smell while driving and after I turn off engine
Old Dec 15, 2015 | 12:25 AM
Ricky_rozzayy's Avatar
Default Weird smell while driving and after I turn off engine
I was wondering if anyone could help me get to da bottom of this it's like a burning type smell and I know I have a broke sway bar link and I was thinking that my sway bar might have moved and was rubbing on something but jus wondering if any one could maybe give a reason why it would be smelling like that
Old Dec 15, 2015 | 12:48 PM
Budsjlm's Avatar
So does it smell like rubber, a plasticy smell, sweet, or burnt oil,
First thing I personally would do is pop the hood an see if I can see anything smoking, and start sniffing around
Old Dec 15, 2015 | 01:16 PM
There's no smoke or anything jus like a burning smell like plastic
Old Dec 15, 2015 | 08:53 PM
Question
Things to check.
1. look at the disc brake rotors and see if they are worn or Hot?
2. It could be the Catalytic Converter they will smell sometimes.
3. Most likely it could be a antifreeze leak and its spilling onto a hot surface.
4. Check your antifreeze level maybe low.
5. Also check the serpentine belt to make sure it is rotating freely and there aren't any pulleys that are froze.
6. Check to make sure the wires on the engine are still covered sometimes they have tape on them and it unravels and gets on a hot surface.
7. Check you underside of the exhaust system to make sure you didn't run over a plastic bag and it's stuck to the hot pipe someplace.
If that doesn't solve anything you should check the interior for a hot wire someplace, also check your Fuses to make sure they are factory Fuses and not generic some fuse have been recalled for a defect and won't blow if overloaded and will cause an interior fire.
