Using Seafoam on 05 Supercharged SS
Old Sep 3, 2009 | 02:36 PM
SSmokybear's Avatar
Default Using Seafoam on 05 Supercharged SS
Has anyone used Seafoam on a supercharged SS before? What vac line did you use for the intake cleaning?
Advice?
Old Sep 3, 2009 | 02:39 PM
Brake booster cable, the one near your brake fluid reservoir.
2 person job IMO. So you can hold your thumb over the vacuum leak when you start the car.
Old Sep 3, 2009 | 02:42 PM
SSmokybear's Avatar
What about cleaning the throttle body or MAF sensor? Supercharger?
Old Sep 3, 2009 | 02:53 PM
For that you just pop off the intake hose and spray.
Old Sep 3, 2009 | 02:57 PM
SSmokybear's Avatar
Spray?? I thought it was a liquid container?
Tom
Old Sep 3, 2009 | 03:17 PM
There's also seafoam that comes in a spray.
Or you can buy a specific spray for your MAF.
Or you can use non-chlorinated brake cleaner spray, this way it's multi-purpose and you aren't buying a MAF Cleaner spray just for your MAF which you won't spray often.
Old Sep 3, 2009 | 03:23 PM
SSmokybear's Avatar
Ok cool. can you descreen these MAF sensors??
Tom
Old Sep 3, 2009 | 03:32 PM
I'm sure you can, but I don't think that does anything on our cars but allow anything your air filter doesn't catch to go in.
We don't really have to worry about airflow that much for the de-screen to be effective, it's just like porting a throttlebody for us, no real gains unless your mod levels are very high.
Stuff just gets louder.
Old Sep 3, 2009 | 03:39 PM
SSmokybear's Avatar
Thought maybe because of the SC and descreening the MAF would make some difference. The PCM was done so IDK. thought I would inquire...
Tom
Old Sep 3, 2009 | 03:40 PM
Never hurts to ask.
