tune up supercharger
Old Mar 31, 2025 | 10:33 PM
yowolt's Avatar
Default tune up supercharger
I will be replacing top end gaskets (valve cover, intake}. is there something I should check/replace on the supercharger?
Old Apr 1, 2025 | 06:06 AM
Coupler and SC oil
Old Apr 1, 2025 | 08:58 AM
yowolt's Avatar
Default supercharger
so I just take snout off, no special tools? can seal be replaced?
Old Apr 1, 2025 | 11:19 AM
You just take the bolts off with a socket and pop it apart (takes a bit of force to break the seal).
There is no gasket. Most use anearobic sealer putting it back together. Ive seen some use RTV without issue too, but have never perosnally tried that.
Just use it sparingly - the two surfaces are flat so theres nowhere for the excess to go except to squish out - half of it inside the gearbox. Ive seen people who had put on a fat bead of rtv and immediately torqued it down while still wet. Ended up with a bunch of shredded rtv bits floating all over the oil.
Heavy Chevy 08
Jun 10, 2015 05:51 PM
07ss_ls4
13
May 9, 2014 12:17 PM
Derekl21
Nov 26, 2012 08:28 AM
S.O.G.
Nov 26, 2012 12:38 AM
