-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   6th Gen ('00-'05): trying to find what it is (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/trying-find-what-64362/)
hot-rod_34 Oct 8, 2025 10:08 AM
i'm trying to find what it is and do i really need a plug there is three exit on it or it will it be a code error waitting for anyone to answer me.
https://cimg1.ibsrv.net/gimg/monteca...42d5edd3ee.png
bumpin96monte Oct 8, 2025 10:19 AM
Can you clarify / restate the question?
The picture shows a supercharger and lower intake manifold from a L67 3800.
hot-rod_34 Oct 8, 2025 11:05 AM
that part do you know name or not and does it need a plug on it.
bumpin96monte Oct 8, 2025 11:23 AM
I do know the name: the picture you posted is a L67 supercharger, a L67 lower intake manifold, and the bolts that hold the supercharger to the intake. Did you intend to circle something specific on the picture for us to identify?
The plug question is confusing - are we talking electrical or vacuum (or fluid if you're talking about the snout fill port / pulley vent)? Is the part you're asking about on the supercharger or the lower intake? Can you provide any kind of location guidance - IE the vacuum port on the LIM under the supercharger snout, the electrical plug on the supercharger bypass valve, etc.
We need more detail on what you're actually asking about here to be of any kind of help. There's multiple plugs / ports on the image you posted.
hot-rod_34 Oct 8, 2025 11:49 AM
the part i will need to know
what is that part that in a circle and arrow that show the part name and i would like to know if i will need a plug or not on it.
https://cimg0.ibsrv.net/gimg/monteca...6a91ae1297.jpg
bumpin96monte Oct 8, 2025 01:18 PM
That plastic part with the hose barbs poking out is called a 'vacuum source manifold' or 'vacuum cap'.
If you dont have a hose to attach to every barb on it, then the open ports absolutely must be capped. It's open inside to the pre-boost portion of the blower / intake tract to act as a primary vacuum source.
If a port is open to atmosphere, it'll constantly suck in air. That air will be coming in after the mass airflow measurement (which tells the engine how much fuel to add), so it won't run correctly.
hot-rod_34 Oct 8, 2025 01:24 PM
i don't have a can they are discontinu those cap do you know were could i found some i don't have it here.
bumpin96monte Oct 8, 2025 01:40 PM
It's missing completely? Yeah, you cant just plug that. If nothing else youre not going to have vacuum for your brake booster.
Try searching PN 24503488, that seems to come up with a lot of hits on google searching that name with 3800 / L67. Seems like a lot of places online stock that one still. Double check the PN interchange to be sure it shows fitting your specific year though.
Another option is ZZP just came out recently with an aluminum cap. Little more expensive, but it should last a lot longer than the plastic ones do.
hot-rod_34 Oct 8, 2025 01:46 PM
i ask for the plug and that what i need it ..
hot-rod_34 Oct 8, 2025 02:01 PM
where can i tried to find it the ZZP and can you show me the ZZP and how much they will cost.
