transmission question
Old Feb 28, 2009 | 01:50 AM
2003supersport's Avatar
Photobucket
Monte Of The Month -- May 2009
Default transmission question
since it seems like my tranny is feeling shaky lately, i might need to do a rebuild or have it looked at. i know it costs quite a chunk of $$ to get that done. Since i would need to do that, i was thinking about putting in the HD (04 +) trannys in mine instead of rebuilding the stock one.
Would i need to do anything special to get this done? or could i simply just swap out the tranny? It will fit no problem right? anyone done this with any complications?
Hopefully i can find a good used HD tranny and try to work a deal to scrap the stock one so it dont cost as much. Might as well get a stronger one right? I do plan to super or turbocharge it in the future anyways.
thanks!
Old Feb 28, 2009 | 03:00 AM
Photobucket
Default RE: transmission question
actually, zzp makes a HD upgrade to add to my non HD tranny. would this be best, along with getting my transmission checked out? As i was reading, i was trying to figure out if i should upgrade the torque converter. my car has 60,000 on it. Also, if anyone could explain what the different gear ratios would do for me? i've never understood gear ratio's. I like balanced gears, but i would like to see better launches....any suggestions?
JuniorCar
22
Nov 3, 2014 11:51 PM
freeguy555
May 23, 2008 07:32 PM
mtwallet
Apr 29, 2008 10:27 PM
bRitch022
Apr 2, 2008 06:29 AM
Aaron_Provost
Dec 12, 2007 08:17 AM
