Tranny swap help
Old Jan 9, 2011 | 02:30 AM
vikingmjj's Avatar
Default Tranny swap help
HI I have a 96 monte carlo with a 3.1 and i took the tranny out of a 95 lumina that i was told was good but the transmission has been in fail safe since it was put in. I am wondering if there is a way to get it out of fail safe or what i can do about it to make it better. Any ideas would be great
Thanks
Old Jan 12, 2011 | 06:16 PM
Kuztom Dreamz's Avatar
Default tranny swap
Hey don't worry too much it is probably minor, i'm sort of almost in the same boat as you. From my experience and research, it seems the 4t60e varied in programs and i believe ran in two year increments. 92-93, 94-95, 96-97 with that being the last year for it. Do you still have access to the donor car? Have you tried to switch PCM's? If not, I would be looking into getting yours reprogrammed. Also make sure all your electrical connections are secure
DeanMachine
Nov 2, 2011 10:45 AM
86ss montettop
Aug 3, 2011 02:40 PM
slinkeey
Feb 3, 2009 10:33 AM
couch
May 11, 2008 11:27 AM
loudNproudSS
Apr 26, 2008 09:35 PM
