Tranny...
Old Aug 29, 2012 | 01:45 PM
Sanjay Collins's Avatar
Default Tranny...
I did a thread a few weeks ago about my 05 SS doing perky shifts into R and D. Now the past couple weeks the shifting motion and feel while driving have become a little more noticeable. It isn't slamming or slipping but you feel it a lot more than before, mostly in 1st and 2nd, hardly ever in 3rd and 4th. And it doesn't always do it. I checked the dipstick and the pan for flakes but I've found none. The fluid is normal colored and doesn't smell/burn but it runs up the stick a couple inches passed the last dot marker. Maybe there is too much? Maybe a bad solenoid or sensor? Or maybe needs a flush? I figured I'd see what you guys think before paying a dealership $125 for a diagnostic just to assume I need a new transmission right off the bat like they always do. It has 54k miles.
Old Aug 30, 2012 | 12:41 PM
2005ssmonte's Avatar
The tranny that the 6th and 7th generation has is about as worthless as a Sebring... They're really not built to handle the HP we get with our cars so they tend to be the first thing to go, but with a rebuild the problems should be fixed with hardened clutches, new solenoids all the beneficial upgrades that GM put out... So i wouldn't be surprised if you needed a rebuild, that's how mine started messing up and I ended up ruining my transmission...
Old Aug 30, 2012 | 01:50 PM
I figured as much, I was just hoping it was one of those rare cases where something was just plugged or clogged, lol. I know what I'm spending my tax return on... again >
Old Oct 1, 2012 | 11:42 PM
Domo01SS's Avatar
I'm having issues with my Tranny on my 01 SS too... . It won't shift out of 1st until I hit about 40 mph. It's not all the time, but about half of the time it does do it. Everything else is fine though... Any advice???
Old Oct 2, 2012 | 12:30 PM
whats your rpms running at before it shifts i believe mine doesnt shift till 40 if im running it harder than normal
Old Oct 2, 2012 | 12:36 PM
Domo01SS's Avatar
As weird as it sounds, it NEVER does it if I run it hard. It usually occurs when I'm just cruising around 26.5-3k. It feels like it doesn't want to catch, and there's like a pause.
Old Oct 2, 2012 | 03:11 PM
bizparr's Avatar
Unless im missing something here, for you to be going 40 mph in 1st gear your RPM's would be above 5k, easy. Perhaps your tranny is slipping a bit going into 2nd and you don't notice it actually shift?
Old Oct 3, 2012 | 06:47 PM
Domo01SS's Avatar
I'm just horrible at explaining it because I'm at school and away from my car. Lol. So since it's been a week since I've driven it, it's kind of tough to explain. I felt like 2-3k rpm's was what I was going. I NEVER floor it because I am scared of GM's Trannys. But yeah, in cruising speed, I hear my motor revving, and when it revs to shift gears, it stays in the "Shift mode" for more than a couple of seconds before it actually gets into 2nd gear. I'm terrible at explaining things. Lmao.
Old Oct 3, 2012 | 06:49 PM
Domo01SS's Avatar
Also, does anyone know of a different tranny that can be used in a MC besides the 65E? This is my 2nd one this year, and this one is going... . My buddy said that he put a 700r4 in his last year, but I have a tough time believing that since that's a RWD tranny and his Monte isn't.
Old Oct 12, 2012 | 09:56 AM
Domo01SS's Avatar
Ok. Better explanation. At about 2.6, the car acts like it doesn't want to shift when it is supposed to. Instead of taking the normal .65 seconds to shift, I would have to wait about a second and a half. Another guy on the forum tells me that it may be a 1-2 shift solenoid. What do you guys think?
