Top swap - how much boost?
Old Jun 24, 2011 | 05:34 AM
Change the oil every 30k
Old Mar 12, 2013 | 11:54 PM
aintnunbutapenut's Avatar
you've probably got your answer, but jic, reseting your tire mon all you have to do is turn off the radio and hold the display button in until you can read "settings" on your radio screen. Once you see that let go of the display button and scroll left or right until you see "tire mon" press display again and it's going to ask you if you want to reset. once you reset it, scroll through the settings until you see "exit" and hit the display button to exit. that should do it. ohh and this is directly from the cars manual.
Old Mar 13, 2013 | 08:50 AM
Mike 00LS's Avatar
Option B is with the key in ACC or ON just pull the headlight switch out and in 3 times. Once you hear the chime the TPMS is reset.
One Dark SS
Sep 27, 2009 11:51 AM
fxdrider
Oct 1, 2007 09:39 AM
schroederdion
Jun 29, 2006 09:16 AM
85_Monte_SC
Mar 24, 2005 12:42 AM
Boost
Oct 20, 2004 10:53 AM
