Top swap - how much boost?
Old Jun 16, 2011 | 06:40 AM
LW57912's Avatar
Default Top swap - how much boost?
As the title says...how much boost can be expected on a stock top swap setup?
Old Jun 16, 2011 | 07:43 AM
Depends on your mods, tune, pulley size, etc.
Old Jun 16, 2011 | 07:49 AM
Enzo354's Avatar
STILL SLOW
With a stock 3.8 pulley, 5-7 lbs.
Old Jun 16, 2011 | 04:07 PM
nitehawkjcb's Avatar
This
Pending altitude, how cold/warm the weather is, etc
Old Jun 18, 2011 | 06:21 AM
LW57912's Avatar
I am at 600ft above sea level, it's 70-80°F, and I am only getting 2-2.5lbs on my boost gauge and my aeroforce is about the same.
Old Jun 18, 2011 | 01:21 PM
Unplug the boost bypass valve from the solenoid (vacuum line, and electrical connection)
Then you should run the correct amount of boost
The BBV is the round black thing that one of the vacuum lines atop the supercharger go to, on the front of the motor.
Old Jun 18, 2011 | 06:38 PM
LW57912's Avatar
Ok, do I need to put a cap on the vacuum line that I remove?
So does this basically stop the BBV from working? Sorry for the newbie question
Old Jun 19, 2011 | 01:24 AM
This is what you need to do:
Remove vacuum line from BBV to BBV solenoid. Don't cap it.
The vacuum line that goes from the fuel pressure regulator to the BBV solenoid can be removed, and just cap the T on the FPR, or put a vacuum elbow on the FPR (to remove/bypass the BBV and solenoid altogether)
This will stop the boost limiting you're experiencing. It makes the BBV run off vacuum, so it still works, it just won't limit boost. I think the PCM tells the BBV solenoid to drop boost down at around 100 MPH, but don't quote me on that.
Bypass it. You won't be sorry.
Old Jun 19, 2011 | 11:48 AM
LW57912's Avatar
Cool ,thanks for the details on how to do it. Done!! up to 5psi now. Now I need to do some mods to get traction lol
Old Jun 24, 2011 | 02:05 AM
ladderman100's Avatar
Default blower oil????
does any one out there ever change or add oil to the blower 3.8 series 2....04 monte ss?
also my add tire air light is on....how do i reset it????all tires are good.....???
