Those Dang Blasted Coolant Elbows
Old Sep 29, 2013 | 07:46 PM
JC Colon's Avatar
Default Those Dang Blasted Coolant Elbows
I got them done. But the Old man in me pushed the lower elbow into the head too far. It's suppose to be placed into the Tensioner housing and then placed and bolting it in seats it. They dont tell you that in the videos.
Both mine were cracked. The upper one was cracked on both ends and the lower one was cracked on the engine side. Hopefully I will not have to do them again But if I do, I WILL KNOW what Im Doing! I hate learning from my Mistakes but, I Am LEARNING.
Still have to do the Trans Fluid and Filter. Since ive done it a few times on other cars it should be a breeze? (Fingers Crossed!)
Attached Thumbnails Those Dang Blasted Coolant Elbows-20130929_160757.jpg   Those Dang Blasted Coolant Elbows-20130929_160708.jpg
Old Sep 29, 2013 | 08:22 PM
z34phoenix's Avatar
did you use the aluminum ones?
Old Sep 29, 2013 | 08:26 PM
owens91's Avatar
Carefully pullin them out to fix them if needed they might break if u didn't get those aluminum ones
Old Sep 29, 2013 | 08:30 PM
JC Colon's Avatar
No I used the plastic cause The_Maniac said that they should be OK. But I am not using Dex-Cool either. Just regular 50\50. Also, you can see that the ones I bought were constructed different from the ones I took out. They Did brake apart when I removed them But the Video I watched on YouTube, (An MCF member) warned of that so I was ready for it!
Old Sep 29, 2013 | 08:34 PM
owens91's Avatar
Well I hope u don't have this issue again
Old Sep 29, 2013 | 08:37 PM
JC Colon's Avatar
At Least I will know what I am looking for (The Symptoms) and how to do it! I make Mistakes, and I Learn From them.
iMSeRiOuS
23
Dec 23, 2012 08:48 PM
Budsjlm
23
Nov 11, 2012 06:07 PM
muleys99
May 2, 2012 08:40 PM
adoublearonn
May 2, 2012 02:29 AM
jcoeracing97
Sep 24, 2010 08:41 PM
