-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   5th Gen ('95-'99): Thermostat (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/thermostat-34721/)
Leprechaun93 Mar 6, 2012 12:59 PM
Thermostat
Has anyone done a thermostat change on the 3100? I really need to change mine and i'm wondering if anyone has any info/pics/tips. Would be greatly apreciated:thumbsup:
ChibiBlackSheep Mar 6, 2012 01:04 PM
remove the air intake duct to the t/body,
unhook the coolant lines from the t/body,
remove the throttle body,
now there is two 13mm bolts.
the rear one actually has a slot in the therm housing, so you can leave it still in there by a few threads and pull the housing off, and get the t/stat out and put the new one in, put the housing back on and then just tighten that rear bolt. put the other bolt in and put it all back together.
Leprechaun93 Mar 6, 2012 01:08 PM
ah geez i heard it was complicated:facepalm: But thanks for the steps:thumbsup:
ChibiBlackSheep Mar 6, 2012 01:09 PM
I believe you can also try to remove the crossover for access, but the throttle body is easier
I'm so glad all of this isn't necessary on the 3.8 ;)
Leprechaun93 Mar 6, 2012 01:14 PM
Well hopefully once i get it changed i'll have some heat and a few more mpg's
Budsjlm Mar 6, 2012 02:13 PM
http://imageonthefly.autodatadirect....755&HEIGHT=500
only one like it i have done is one of these... slightly different than a monte but the same...
make sure to bleed the system when your done too
Leprechaun93 Mar 6, 2012 10:17 PM
Good point, does the 3.1 have a bleep screw anywhere? and any specific coolant or just any old 50/50 mixture?
lougreen03 Mar 6, 2012 10:34 PM
Yea I did one on a 3400 before too. It's a little challenging but you can handle it.
Rellsun Mar 6, 2012 11:15 PM
there are two bleeder screws one is on the thermostat housing. the other is right on top of that black pipe by the water pump
Leprechaun93 Mar 6, 2012 11:19 PM
thanks for the tips everyone, when i get to a day where i dont need the car i'll hopefully take a stab at it
