Synthetic oil vs regular
Old Jun 16, 2012 | 11:43 PM
  #31
bblackstone's Avatar
I go with EDGET1530 CASTROL EDGE TITANIUM OIL. You cant go wrong.
I have been running this for about 30,000 miles. This weekend a newly aqainted friend of mine who runs a speed shop in Sumner WA, helped me open the motor up just to see how she looks. He agreed with me the motor looks incredable. I started using this oil when It was around 90 G's.
No visable damage to the gaskets. Go with what you can afford.
Old Jun 19, 2012 | 10:18 PM
  #32
Zeke's Avatar
Amsoil - 0w-30 Signature Series 100% synth motor oil ... along with an Absolute Efficiency filter, & call it a day, better yet, a year, ... or 15,000+ miles. After that, change the filter, I prefer Wix, & you are fine for another 6-10k miles.
Everybody here has given their "IMHO", etc., & what they have heard, etc. Here is a fact from my life. 2002 Chevrolet Avalanche 5.3L V8. Run Amsoil since day 1. Have changed the oil 4 times on it. 35,000 mile increments. First 15k miles run Absolute Efficiency filters, then every 7500 miles, change filter only - Wix - and fill the filter with oil, & carry on. Always Amsoil 0w-30 Sig. Series 100% full synth. Also, when the oil is fully changed, instead of filing the filter with the motor oil, it is filled with Marvel Mystery Oil. The truck is driven in L.A., CA.
I will also say that anyone, & some have on these forums, that do NOT pre-fill their filter with oil before starting, are out of their minds.
Old Jun 19, 2012 | 11:08 PM
  #33
BlackRainSS's Avatar
Originally Posted by SupplySgt
If you're planning on draining the oil when you store it, then it may not be worth it to go synthetic. We have enough nice days even during the winter where I can drive the Camaro, so I'll never store it (I'll have a garage for it in a few months anyway) and occasionally drive it during the winter. That's why I'll be going synthetic when I rebuild it. I want to be able to just randomly decide I want to drive it to work. And since the heat works really well, I can do that and not be uncomfortable. It's actually more uncomfortable during the summer (no AC) than during the winter. But since I work nights, it's not as bad. Only time I'll drain the fluids is when I deploy.
When I swap in the 6.0L in my truck I'll probably go synthetic as well and run longer in between oil changes.
I'm seriously considering changing to Royal Purple after all I've heard. Whats keeping me frrom it not is the fact that: 1-I dont drive my Monte a lot at all right now it has 78,200 miles and I bout it with 77,000. 2-I changed the oil on it right when I got it just as a precaution and only put 850 miles on it before storing it and then onc eout of storage changing it again, so my oil is changed well before 3000 miles. 3-I heard its not worth it unless you get every last drop of dino oil out. and last of all 4-if i do switch i'm thinking it'd be better to wait until its driven more regularly, is that a good idea? Any input on that would be great also.
Old Jun 20, 2012 | 08:00 AM
  #34
Cowboy6622's Avatar
*sigh*
Yes, lab tests have shown that even 1 single drop of organic dino oil can ruin 5 quarts of synthetic motor oil.
That's sarcasm.
Please, think about it. Oil is clingy and slippery. When you change the oil, you're not draining every drop off every cylinder, getting every drop off the valve train, getting all the residue off the pan.... it's impossible without stripping the engine down. But by just changing the oil and putting synthetic in there, you'll have it about 90-95% syntehtic, and 5 % organic oil will not ruin the oil. Engine flushes, so far as I am concerned, are just a way for mechanics to make more money off of you. Heck, they busted Jiffy Lubes and even a GM dealership in Cali (someone on here posted the video) not doing engine flushes when they allegedly were.
Please, stop over thinking this....
And if you're going to store the car, I say synthetic should be better because it shouldn't break down just sitting there like organic oil will.
Old Jun 20, 2012 | 08:17 AM
  #35
03SSLE's Avatar
Anyone that tells you that dino oil and synthetic oil can't be mixed is perpetuating a myth. Lots of oil companies offer what they call a semi-synthetic oil which is part dino oil and part synthetic oil. Dump the dino oil, put the synthetic in and don't worry about it. IMO royal purple is overrated. It doesn't offer any more protection then a lot of other synthetic oils on the market but is priced twice as high. Of course, you do get bragging rights with that higher price.
Old Jun 20, 2012 | 08:22 AM
  #36
Cowboy6622's Avatar
and as I said a couple pages back, I think those said myths were started by the organic oil companies.
Old Jun 20, 2012 | 10:10 AM
  #37
Haha never thought of it that way before. The part about it not breaking down like dino oil when I store it is a good point. I've got about 2k left until I should change my oil. But does anyone have suggestions on what brand to go to? Car has 78k is the other thing :/
Old Jun 20, 2012 | 10:50 AM
  #38
Mike 00LS's Avatar
I use Castrol Edge with Syntec (full synth). Switched over from conventional at about 70k.
My mechanic's son (who is a mechanic at his dads shop) b*****d me out left and right when I told him that I switched. "Well, changing to synth can actually eat your seals, etc. anybody recommends if you're going to switch, do it within the first 25k."
I don't see the harm - if you develop a leak AFTER switching to synth or high mileage detergent oil it means you already had a leak somewhere and now you're cleaning the crap that was plugging it.
Old Jun 20, 2012 | 02:27 PM
  #39
#1 stunna's Avatar
My 2 cents
If you change your oil reguarlly and dnt do much "hard" driving , dnt waste the $$$ on the expensive stuff.
Small leaks that you might not have noticed w/ conventional oil -- will probally be seen more with synthetic oil , because it is usually a much "thinner oil" . I witnessed this 1st hand when i changed over to castol synthetic in my retta ( it is an 88 w/ alot of miles ) . I stuck with the full synthetic for ALL my fluids , but I have also replaced nearly every seal or gasket there is... No leaks now!
Old Jun 20, 2012 | 03:39 PM
  #40
I've heard the same saying. But when you can't afford a car with 25k or less its kind hard to do lol.
