I just downloaded two files from the HPTuners repository. They're both supercharged Montes, an 04, and an 05. But in both of them, the VE table only goes up to 140 kpa, which is the same as my NA Monte. I know the files are from supercharged cars, cause the injector flow rate is scaled by manifold vacuum, whereas an NA is static. I thought the supercharged cars had 2bar MAP sensors, so shouldn't the VE table be scaled differently?
Originally Posted by WolvenScout
(Post 722552)
(Post 722559)
I'm pretty sure they have a multiplier in them that HPTuners can't access. I think TinyTuner + DHP was able to make some modifications to that, but they require BIN files and HPT isn't compatible with that stuff anymore.
Would it still work if I took one of those supercharged files and did a write entire to the ECM? |
(Post 722563)
That's weird though that it would be setup that way from GM. You'd think the sensor that is responsible for measuring pressure would have a table properly scaled to measure said pressure instead of just going to 140 kpa, and having a multiplier applied.
Would it still work if I took one of those supercharged files and did a write entire to the ECM? You need to do an OS swap which was what I was saying earlier in the thread. But hey, if you can figure out a simple way to do it, let me know. From what I gathered it's not possible without a new PCM and OS swap. |
I stopped by a junkyard today looking for an ECU from a SC car but ran into a little issue. The only SC car there was a Pontiac GP which had this style of ECU:
https://cimg7.ibsrv.net/gimg/monteca...d507c0a202.jpg My Monte has this style: https://cimg9.ibsrv.net/gimg/monteca...45d277e54e.jpg Do the 04-05 SC Monte's have the second style ECU that would be a direct swap? |
