supercharging
I have a 2003 montecarlo and i have recently bought a stock supercharger from an 2004 monte. Would I have to buy a intercooler, and if so would u know where i can buy one for less than a $1000???
RE: supercharging
you also need the heads and intake for the 04 motor.
if you dont mind me asking what did you pay for the S/C as faras the intercooler it is somethign that you would have to just dig for it. Might beabel to get one out of a diffrent car or diffrent year car etc.... |
RE: supercharging
Big job to do a top swap to supercharge your 3800... search "top swap" on here, or on clubgp, and you'll be able to dig up a parts list.
Good luck! |
RE: supercharging
you might alos look at zzp's ss kit aloows y to uae the sc with out changing heads
RE: supercharging
ORIGINAL: DESS03 you might alos look at zzp's ss kit aloows y to uae the sc with out changing heads just the 4.0 pulley that i started on i felt a huge gain |
RE: supercharging
would still like to knwo what he has got in to it when he is done with it. Im still debating on either a turbo or a S.C.
both would do what i want as a end result. |
RE: supercharging
anyone know where I can find the 3800 Series Whipple supercharger?
RE: supercharging
might check the dealer or the junk yards .
you can also put it on the web threw some of them and they will look in all attached to the site for you . Good luck. im betting they are not going to be easy or cheap |
RE: supercharging
Welcome, nice handle you've chosen there.;)
RE: supercharging
I have a 2003 montecarlo and i have recently bought a stock supercharger from an 2004 monte. [*]L67 Heads (Pair)[*]L67 Fuel Rails[*]L67 Fuel Injectors[*]L67 Pullies (2 idlers and one crank)[*]L67 Supercharger and throttle body (Superchargers are inspected for wear and coupler play and are waranteed for 90 days/ Boost bypass included)[*]L67 MAP sensor and MAP sensor bracket L67 Lower Intake Manifold L67 Valve Covers (pair)[*]L67 Coil Bracket All necessary vacuum line, bolts, and accessories for the job Its a pretty tough job. You can do it with the SS kit from ZZP too, but that'll just bea bit more pricey. ORIGINAL: montecarlo Would I have to buy a intercooler, and if so would u know where i can buy one for less than a $1000??? anyone know where I can find the 3800 Series Whipple supercharger? You can no longer buy one (although there should be one in clubgp's classifieds right now used unless it sold). The guy stopped making them. Its not worth it anyways unless you have a heavily built setup- and even then there are a lot of problems w/ the kit. |
