Supercharger for my 01
Old Aug 30, 2012 | 08:20 AM
I'd rather see you go turbo instead.
It will wind up costing almost the same but you will have much more modification options down the line.
Old Aug 31, 2012 | 01:20 AM
mairj40's Avatar
Here's what you need to top-swap.
M90 Supercharger
Boost bypass valve
L67 smooth idler pulley
L67 grooved idler pulley (on coil pack)
L67 belt tensioner
L67 throttle body
33# injectors
L67 crank pulley
L67 MAP sensor
L67 heads
L67 LIM
L67 Valve Covers
L67 fuel rail
Head Bolts
Rocker Bolts
S/C Bolts
LIM Bolts
L36 to L67 wiring harness adapter kit
Vac lines (I used 7/64" rubber hose)
Coil pack bracket from a 97-98 GT/GTP
S/C belt
2 changes worth of oil/oil filters
2 jugs of coolant
GM S/C Oil (need 6 oz.)
Reprogrammed PCM
Some sort of intake like a FWI or CAI
180*-thermostat
Copper-core spark plugs that are 1 range colder than stock
At least ported manifolds with a 3" downpipe with the u-bend deleted, Headers preferably
Gaskets:
Head Gaskets
S/C gasket
TB gasket
LIM gasket
LIM o-rings
Valve Cover gaskets
Fuel rail o-rings
Gray RTV gasket maker
Teflon tape
Copper gasket spray
Out of curiosity, what happens if you don't up the downpipe size and don't run ported manifolds? Is it just a performance thing, or can you break something?
Old Aug 31, 2012 | 05:24 AM
You need to then run a larger pulley than the stock 3.8 because with the higher compression of your block there's a fantastic chance you will have high KR and could chip a piston.
Old Aug 31, 2012 | 08:59 AM
mairj40's Avatar
Good information. Thanks Chibi.
Old Aug 31, 2012 | 03:42 PM
02 Earnhardt Monte Carlo SS's Avatar
id love to get a turbo chibi but the chances of that happening are very slim, my dad is getting mad about me even thinking about supercharging it so i know a turbo will be out of the question lol.
Old Sep 5, 2012 | 10:21 PM
04chevyboy's Avatar
im thinking of s/c mine over the winter as ihave my truck an save for a big v8 car or tuner car
Old Sep 13, 2012 | 11:55 AM
mairj40's Avatar
Another dumb question...
Why do you need a different coil pack bracket? Is that the whole engine bracket assembly that needs replaced, or just the coil pack bracket part of it?
Sorry. Working on gathering info and parts for a top swap myself.
Old Sep 13, 2012 | 11:59 AM
not 100% but I think it's to move the coil packs out of the way of the supercharger belt.
Old Sep 13, 2012 | 12:30 PM
Enzo354's Avatar
STILL SLOW
There are 100000000 top swap threads on this forum. About 800 of them in the last 3 months. Search.
Old Sep 13, 2012 | 12:54 PM
mairj40's Avatar
Gee, why didn't I think of that? Oh yeah, I did. But none of them answer every question.
