6th Gen ('00-'05): Starts....Stalls....Starts and runs.
Old Nov 30, 2017 | 12:02 PM
josephandn@gmail.com's Avatar
Default Starts....Stalls....Starts and runs.
Hello all,
I have an '05 Monte with the 3.8 L V6. It will fire and then immediately die. I replaced the air cleaner and that helped, but still some issues. It coded with "Bank 1 too rich". I replaced the MAF about a year ago. I am assuming injector issues, maybe fuel pump? It has 130K miles.
Any ideas would help.
Thank you
Old Nov 30, 2017 | 01:56 PM
user 35764368's Avatar
sounds like maybe the fuel presuure regulator
What causes the P0172 code?
  • A dirty mass air flow sensor overstating the amount of air entering the engine which may cause excessive fuel delivery
  • A bad oxygen sensor
  • A leaking fuel injector allowing too much fuel to enter the combustion chamber
  • A faulty fuel regulator, which may not be regulating the pressure of the going to the engine as it should
  • A vacuum leak
  • A possible fault in the coolant system such as a stuck thermostat or bad coolant temperature sensor
  • Worn spark plugs
Old Nov 30, 2017 | 03:54 PM
I was also thinking fuel pressure regulator. Can you keep it alive if you give it a little gas?
Old Nov 30, 2017 | 04:13 PM
SuperchargedMonte's Avatar
You can also ohm the injectors to see if one is way off.
