Starting problem after installing a new thermostat & gasket
Old Apr 30, 2012 | 12:02 PM
edb_app's Avatar
Default Starting problem after installing a new thermostat & gasket
I replaced my thermostat today on my 84 3.8 along with a new gasket. Connected everything back up and it started right up but noticed a bunch of fluid was pouring out around the housing so I immediately shut it off. After I got most of the coolant cleaned up I then drained the radiator again, moved the fuel line and tightened the thermostat housing bolts, refilled the radiator I tried starting again to see if it was still leaking around the housing but it wouldn't turn over. I checked every connection but cant figure out what could be causing it to not start. Does anyone have any suggestions? It has been running perfect and I thought this was going to be an easy job but it is slowly turning into a nightmare. Been trying to figure out the problem for the last couple of hours. Could the leak have caused damage to the starter? Could there be a short somewhere? Any help would be great! Thanks in advance!
edb_app
Apr 30, 2012 01:44 PM
jim fischer
Sep 11, 2011 07:49 AM
Scooby doo
Mar 23, 2010 09:56 PM
RickCoMatic
Jun 5, 2008 12:29 PM
