Start problems..
Okay this isn't a huge deal, the car still runs fine and doesn't die or anything like that while driving, I just out synthetic oil in there andsometimes the temp might get to the middle bar, one of my friends that knows his way around GM cars and trucks thinks I might have put a little too much oil in but not too much. Anyways, when I start the car, from time to time the car will rumble as if it is a 350 V8 or something, the only way to fix it is to push down the gas a little then it goes away, and sometimes on startup(this hasn't happened in a while) the car will die but it starts right back up after. Other than that the car runs good. Any ideas?
Hi `Brendan,
A few questions to maybe help our tech member's help you ?
1. Can't you check your oil level with your dip stick ? (it's either 2 much, or not enough) lol
2. How many miles on your Monte ?
3. Do you have any mod's (If so post them)
Please respond & hopefully someone will have a suggestion to your problem (?)I know that sometimes you can get a bad tank of gas that can
cause same or similar symptoms or moisture in your tank ?
p.s. I'm confused by
Good Luck & I hope a member can help you (?)
Yes, they do.
Hi `Brendan,
p.s. I'm confused by >
1. Can't you check your oil level with your dip stick ? Yeah it says it's full, but
my friend thinks a 3800 is 4.4-4.5 quarts, I probably put around 4.6-4.8 in
2. How many miles on your Monte ? 171k
3. Do you have any mod's? No mods other than my head unit.
cause same or similar symptoms or moisture in your tank? This happens after a hot start though.
And what I meant by too much oil but too much, is that he said it shouldn't be too much to cause a serious problem, but he thinks there's more than there should be.
Hi `Brendan,
I'm confused on what you think it is lol. The throttle body sensors, the MAF, or the IAC? I'll probably clean that IAC first thing I do when I get the chance.
I cleaned the IAC and that seemed to fix the problem.
^It definitely does not look like that anymore, lol.
Cleaning might only be temporary. If it is and you do a full replacement of it it would be good to grab a new TB gasket, and just remove the TB and fully clean the whole thing at the same time.
