Standalone ECU for 3800
I've been tuning my 3800 with HP Tuners for almost a year now, and I'm realizing how limited the P04 PCM is. The problem I'm having in my research is finding a compatible ECU replacement. Something like the Holley HP ECU looks promising, stating it's compatible with 6 cylinder engines and GM sensors. While also having the much needed features for a boosted application like 1-5 bar MAP sensor, traction control, injector drivers, using stock knock sensors, etc. I won't be switching to an aftermarket ECU for a while, but I want to start doing my research. I just don't really know where/how to start.
Hard part is going to be finding someone who's actually done it.
The only ones I've ever seen done on a 3800 are cheapo Megaquirt setups. Ive never seen it done with a nice full feature standalone.
Would be really cool to do for a max effort setup:
-Swap to a DBW TB
-Swap to a good modern ignition system
-Built in ability to multifuel- either true ethanol flex, meth injection, or even a dual inejctor pump/race gas setup
-Launch control, boost by speed, legitimate traction control
I'd love to do that in my monte some day. My big hangup is emissions as it would be an instant fail around here without an OBD port. Swapping back and forth to stock sounds like a giant pain too.
-Swap to a DBW TB
Now that you mention it, I think you're right.
I don't really remember hearing much feedback though after he put it in TBH. Hopefully he'll chime in here.
Id be interested to know if he thought it was worth it- I know they're pretty expensive to buy + the time to install and tune in. Im most curious as to how well the traction control / boost by speed works as that could be a real gamechanger for a high hp FWD setup, especially for anything that sees real street time.
As far as the Holley brand of ECUs go, I believe there's only two options, the dominator (~2200$) and the HP (~1400$). Both of those ECUs are compatible with 4, 6, and 8 cylinder engines. They can both drive over 12 injectors, which is plenty even for a dual injector setup. They can both drive 2 wire ignition coils with an add on module. (Are 3800 coils considered two wire coils? The bottom of the coil only has the two inputs, which plug into the ICM.) They can both do progressive water/meth control if using Holley solenoids. The only major differences I'm seeing are the number of additional inputs you have available. 83 in total for the dominator, including 4 speed sensor inputs which I'd love to use. A disadvantage for the HP is that it doesn't appear to support drive by wire.
I'd really like to hear from the person that may have put a Holley ECU on a 3800, if anyone knows how to get in touch with them.
A side note on emissions. My 2000 is going to be emissions exempt here in a few years. So as far as I'm aware, there's no requirement in Texas for looking into the ECU with the OBDII port after the vehicle becomes emissions exempt, just a safety inspection.
Overall, wiring a harness for one of these ECUs looks fairly simple. The route I'm planning to do is an unterminated harness, so I can wire in all the factory 3800 sensors, but adding an EV1 injector sub harness. The only thing I'm lost on is the ignition side of things. Specifically the cam/crank sensors, and doing the actual ignition coils.
-Swap to a DBW TB
-Built in ability to multifuel- either true ethanol flex, meth injection, or even a dual injector pump/race gas setup
-Swap to a DBW TB
TBH though, I wouldnt bother using an aftermarket pcm that has to still use the stock ICM, thats the worst part of the whole ignition system.
I'd probably at least go to LS coils too to get it a touch more modern than the 80s waste spark. At least then you're not wasting some spark energy firing the gap on an empty cylinder.
The stock coils are 2 wire - theres only 2 terminals on each.
TBH though, I wouldnt bother using am aftermarket pcm that has to still use the stock ICM, thats the worst part of the whole ignition system.
I'd probably at least go to LS coils too to get it a touch more modern than the 80s waste spark. At least then you're not wasting spark energy firing the gap on an empty cylinder.
Since you recommended ditching the stock coils, what about going with Holley's smart coil kit? There would be one coil per cylinder, and they're designed to plug directly into the ECU so they benefit from all the ignition control features.
The only things I'm uncertain about, is if you can use full length spark plug wires with those since technically they're coil near plug.
Any reason you wouldn't just mount the coils on or above the valve covers though- LS style? Certainly a lot less to fail with only a few inches of high voltage vs a few feet.
