Stage 2 Performance
Hey guys, im going to do a stage 2 performance package on my car to see what I can make out of the 3400. The first thing i saw was the milzy package.
this is what comes with:
Kit includes:
-MMS Stage 2 heads
-MMS Stage 2 cam
-MMS Complete heads and cam install kit
-MMS ported intake manifolds
-MMS Stage 2 PCM
-MMS 180 t-stat
-MMS 36lb injector and harness kit
-MMS chromemoly pushrods
$2,749.99
im wondering what else i should probably get with this build and if theres a cheaper place to get these parts. links would be best.
im looking to start buying parts early.
Kit includes:
-MMS Stage 2 heads
-MMS Stage 2 cam
-MMS Stage 2 PCM
-MMS 180 t-stat
$2,749.99
It looks pretty cool but it's on the expensive side of things too. Just keep in mind that a turbo build would be pretty similar in price and give you much better gains.
Either way, I like where you're going with the Monte. Performance is fun
Gonna do that, then do turbo? Smarter then just turbo but it depends what your going for.
Not trying to deter you from modding the monte- its just a lot of people used to go the NA route on 3800's- and the hp/$ just isn't there compared to a boosted setup- much less compared to modding LS engines.
Search for Grand Am performance parts. They had the 3400 as well. If you're really serious about getting into the performance of your 3400, you should visit http://www.60degreev6.com and check out their forum. I've never joined, but lots of knowledgable people about 60* V6 motors specifically are up there.
