Spark Plug info PLZ help
Old Jun 8, 2011 | 11:00 AM
06-montelt2's Avatar
Default Spark Plug info PLZ help
I was told that for my platinum sparks, that they do not need to be gapped. Is this true?
Its an 06 3.5 BTW
Old Jun 8, 2011 | 11:15 AM
06MonteSS's Avatar
that's because they probably come gapped at .040 already, which is the gap they should be at for your car...
I would still double-check the gap on 'em tho...
Old Jun 8, 2011 | 02:36 PM
Sparky-88's Avatar
Always check your spark plug gaps. New plugs may come 'pre-gapped'. But every time I check new plugs, I find some that are NOT gapped properly. Since it's simple to do BEFORE your install them (and a pain to take them all out while trying to diagnose a poorly running engine) and costs nothing but a few minutes of your time, ALWAYS check the gaps on your plugs.
Old Jun 8, 2011 | 03:14 PM
CRAP!!!! sorry guys i ment to say iridium spark plugs. Yeah Iridium plugs are apparantly what came stock with the car and i was wondering if IRIDIUM plugs need to be gapped, not platinum. Sorry But excelent advice from the both of you!!!
Old Jun 8, 2011 | 03:33 PM
03SSLE's Avatar
Whether they are standard resistor type, platinum, iridium or any of flavor of plug it is always a good idea to check the gap prior to installation.
Old Jun 8, 2011 | 07:04 PM
x2- I bet the reason they say not to touch them is they don't want someone jamming one of those twist gages in there and breaking off the tiny electrode they use on new plugs.
When I just did new iridiums in my Impala a couple weeks back- they were all spot on- but if you're going through all that hassle to change the plugs, I'd take the extra time to make sure its correct- just don't put any force into it at all.
Old Jun 8, 2011 | 09:42 PM
RickCoMatic's Avatar
I always check them.
It takes 5-seconds.
Usually, they-re right on-the-money.
But,, I check them anyway.
Old Jun 9, 2011 | 12:54 AM
I agree, never install any new plugs with out confirming the correct gapping, ever!!
Old Jun 9, 2011 | 11:14 AM
Yeah i should have at least checked them, well im gonna take a look at them once i have the time and i will let you guys know if they where improperly gapped. BY THE WAY does anyone know what size gap is called for on a 2006 3.5 LT?
I apreciate all the info fellas!
Old Jun 9, 2011 | 11:20 AM
gap should be .040 inch, just looked it up in my Haynes manual
