Shifter cable adjustment?
Old Sep 26, 2010 | 09:38 PM
PhotoKIrk's Avatar
Default Shifter cable adjustment?
Hello
I had a momentary attack of stupid and changed the setting on the shifter cable of a 97 Monte Carlo LS. (removed the clip, tugged the cable, whole nine yards). Now Park isn't Park and Reverse is somewhere between Drive and Neutral.
Can anyone help me get the shifter and cable adjusted correctly? Thanks!
Old Aug 12, 2012 | 07:55 AM
3.4Dually's Avatar
ive got a similuar problem but unfortunitly no one likes to answer threads on this forum, theres also realy not a whole lot of info on this forum for monte carlos, atleast not like my other forum for my bronco, fullsizebronco.com there you can find any answer to any question possible that has to deal with broncos.
kinda disapointed with the lack of knowledge about monte carlos on the interwebs
Old Aug 12, 2012 | 08:10 AM
blueSS's Avatar
This is a 2 year old thread and you're obviously trolling
Old Aug 12, 2012 | 12:00 PM
zzapultimate's Avatar
See the black cable with the plastic adjuster on it I pointed to in this picture? That's how you adjust your shift cable. Pop the clip on the adjustment piece on the cable and the cable can be slid freely to adjust it to exactly where you want it.
To get it back in correct adjustment. Put the car in park and apply the e-brake. Pop the clip on the adjuster on the shift cable. Now put one hand on the adjuster, and one hand on the shift cable towards the firewall and push together. This will slide the shift cable all the way to park on the transmission. If you look down below the brake fluid reservoir, you can see the end of the shift cable where it connects to the transmission. I believe in park, the lever on the transmission should be all the way towards the firewall, and if it were in D2 it should be pointed all the way towards the front of the car.
How about next time you ask nicely
Old Oct 8, 2012 | 02:04 PM
3.4Dually's Avatar
^^^ now thats a great post and oddly enough you posted it on my 24th birfday!!
an as far as my last rude post i was tryin to show my point....there is alot of threads on here about problems I and probly others are having but few have been answered
thanks for the help guys
Old Oct 8, 2012 | 03:34 PM
Happy belated birthday. Did you get your shift cable figured out?
Old Oct 16, 2012 | 10:05 PM
3.4Dually's Avatar
thank you and yes... now to find and fix my cyl 5 random misfire problem
TSauer09
Jul 13, 2022 02:46 PM
DerrtyD
Dec 29, 2014 08:16 PM
TSauer09
Jul 22, 2013 07:40 PM
matrx10503
Dec 13, 2011 11:43 AM
Alienwordz
Nov 6, 2011 01:00 AM
