-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   Shift kit worth it? (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/shift-kit-worth-42372/)
Frosty LS1 Apr 7, 2013 08:03 PM
Originally Posted by iMuf (Post 540693)
already done haha. I did that around 56k which was very very shortly after I got the car. Why should you never do a full flush?
Well, I can't give any personal experiences, but I hear a lot of horror stories from cars that get a fluid flush. ESPECIALLY on older cars with higher mileage. Yours is kind of middle of the road on age and mileage now, so it might not affect yours, but I'm not sure.
I've just heard the flush is hard on the tranny, and sometimes cars emerge with serious problems and sometimes actually become undriveable after a flush, even if it was done professionally. I would only recommend flush on a new car with less than 30,000 miles.
red04montels Apr 7, 2013 08:44 PM
Generally people don't recommend them on higher miles, like 150k or so because the metal shavings in the fluid make it thicker or something... It's just a bunch of theories and biases that generally don't mean much.
If you take car of your transmission and do regular flushes and filter changes it will more than likely treat you well
ZIPPY02 Apr 7, 2013 10:07 PM
You only need to remove the transmission pan to install the shift kit. Pretty easy cheesy.... The cooler might take longer to put in and it's not even that bad. You can get almost any fluid cooler to use off of eBay. I prefer Earl's Coolers myself. I actually have 2 coolers mounted directly behind my High Sports grille and the tranny fluid stays very chill.
http://www.ebay.com/itm/Earls-Temp-A...91662b&vxp=mtr
xxtheshockerxx Apr 8, 2013 12:16 AM
I would recommend a shift kit. I have the Transgo one in my 2007 SS and it changed how it would downshift extremely well. The stock shifts seemed sloppy and now it is much better after install
iMuf Apr 8, 2013 06:02 AM
Thanks for all the help guys. I do have a couple more questions, what trans is in the 06'? I have done a little research and it looks like it is the 4T65-E, would that be correct? and also have you guys disabled DOD if you have it? I have heard that isn't all that great for the car as well.
ChibiBlackSheep Apr 8, 2013 07:57 AM
You have the 4t65e-HD trans like the supercharged guys.
zjerry Apr 8, 2013 08:44 AM
It's easy to install a shift kit. I put one in my Monte SS & my wife's Impala SS.. Here's a LINK:Shift kit install, - LS1TECH
iMuf Apr 8, 2013 08:57 AM
Thanks guys, I appreciate the help
red04montels Apr 8, 2013 10:10 AM
Get rid of DOD, it gets rid of those beloved oil issues and your car won't sound like a helicopter at cruising speeds.
xxtheshockerxx Apr 8, 2013 11:17 AM
not even that...it just makes the car run so much smoother. one of the best things I have done to my car
