Shift kit worth it?
Hey everyone, I have an 06' Monte SS and at some point I want to beef up my transmission since they are notoriously bad. I have been looking at shift kits and it looks like, for the money, that could be a pretty good thing to do. What are your guys opinions on shift kits, have you guys all done them? and if you guys think it is worth it, is there a particular brand you guys/girls recommend? and is there anything else I can do to beef up my trans on top of a shift kit? I plan on doing a few performance mods such as a CAI, supercharger, exhaust, as well as get it tuned. So I want to make sure I beef up the trans as much as I can before I get to far into the all of those performance parts.
Curious, what supercharger are you going with? I don't think I've seen a supercharged LS4 before.
The only thing a shift kit will really do is reduce the time between gears when shifting. Where most cars have a soft shift between gears, it's because the gears are floating, which is also bad for the gears. So in theory, a shift kit will firm up the shifts, creating less floating time between gears. The core of the problem is the transmission for these cars are too weak. Their horsepower limit is 300HP, out of the box they are already matted to a 303HP V8, so they are notorious to go bad. When it come to the internals of the transmission I'm not sure what you'd need to replace to make it stronger. I know there are some places that will offer a built transmission purposely built for racing for you. They cost around $1,500-$2,000 though, but can hold upwards of 500HP I believe. |
Part of the work that I did to my car included the TransGo shift kit. There was an immediate difference that I could feel. Just the fact that my transmission is still working should be a testament to the product. If I could start all over, I would add an aftermarket transmission fluid cooler while I had it so far apart. Good luck!
As he stated above ^
A transmission cooler can be had for around $150-$200 from ZZperformance I believe, a good investment. |
Originally Posted by Frosty LS1
(Post 540679)
Is a shift kit as well as a cooler something that is fairly easy to install with some basic tools or is it something I should take to a shop to do? I rebuilt a ford thunderbird transmission which wasn't to bad. So I can't imagine something like this being any harder. But it's always good to know what you are getting into before you get into it.
Originally Posted by iMuf
(Post 540686)
Next best mod for this car, change the fluid! Most people say change it at 100k miles, don't wait that long. Drop the pan and change that fluid now, just never ever do a flush! :thumbsup: |
With the kit I used, it was basically just replacing the accumulator springs. It was pretty straightforward for the (1-2) and (2-3). If you want to go any further than that, I would recommend taking it to a mechanic. You should be able to do a tranny cooler by yourself with no problems.
The directions provided in the kit were very straightforward. Even included how to remove your current fluid. |
Originally Posted by MillerMonteSS
(Post 540688)
(Post 540687)
I personally have no transmission experience. If this is your DD and only car that you have, I would avoid that, unless you know exactly what you're doing. The risk of damaging something and being without a car until it's properly repaired is too great.
| All times are GMT -5. The time now is 02:22 AM. |
