Scanner?
Old Jun 12, 2008 | 06:39 PM
Submariner's Avatar
Default Scanner?
I'ma total newbie when it comes to scanners so I need help. Is this the kind I want? The reasonI'm looking is my next mod will be a smaller pulley and everythingI've read here recommends a scanner to check for KR.
http://cgi.ebay.com/Automotive-Scann...QQcmdZViewItem
Old Jun 12, 2008 | 07:17 PM
kweef's Avatar
Default RE: Scanner?
well ive never even heard of that scanner and i didnt read anywhere that it has the ability to reprogram your pcm...i know its expensive but i would suggest an hp tuner...its costly but there are so many things u can do with it...or send ur pcm to a company like zzp performance and have them retune it
Old Jun 12, 2008 | 07:41 PM
Submariner's Avatar
ZZP did my PCM. A search of this forum mentioned a Palm scanner so I was curious if this was the same. The search also mentioned you should check for KR. Also I did e-mail ZZP listing all my mods and asking what they recommend for a pulley size. Lastly good point about not being able to adjust settings.
Old Jun 12, 2008 | 07:46 PM
kweef's Avatar
yah from what i understand u can monitor everything but not reprogram anything and therefor not change ur settings for the smaller pulley
larrin928
Jun 2, 2008 10:25 PM
RickCoMatic
Feb 19, 2008 08:01 AM
Chucks88SS
May 5, 2007 04:46 PM
01BlkSS
Jan 3, 2007 12:44 AM
