Rpm drop on my 07 SS
Old Jun 18, 2012 | 03:40 PM
xxtheshockerxx's Avatar
RED DEVIL
Default Rpm drop on my 07 SS
Hey everyone. I have been experiencing some trouble with my 07 Monte SS. When I am going down the highway around 60 mph and hit the brakes to stop the rpms will drop down to nearly 300 at about 30-35 mph then jump back up to around 1000 or so. The car died twice the other day and every time you can feel it almost stop running. The issue happens nearly every time i slow down from highway speeds. Any guesses on what it could be? I was told once today it might be the Torque converter staying locked up too long.
Thanks for the help
Zach
Old Jun 18, 2012 | 03:57 PM
Try cleaning your MAF sensor too.
Old Jun 18, 2012 | 04:02 PM
Does the engine skip & kinda idle rough?
Old Jun 18, 2012 | 04:24 PM
RED DEVIL
i was going to do that to make to rule that out.
no it idles really smooth and the engine doesnt skip.
Old Jun 18, 2012 | 04:41 PM
Hi `Zack,
Sorry to read about your problem with you Monte, but it's great to see you online & that you are OK...
Post a update on our Blog & tell us what's been happening in your life. I hope one of our member's can help on your problem. Sure hope it's something minor...
How long has it been happening ?
Does it feel electrical ? fuel ? (When is the last time you change your fuel filter ?)..Is your transmission shifting smooth ? Any hang `up in gears ?
Good Luck 4-Sure
Old Jun 18, 2012 | 04:56 PM
Highly doubt its the MAF if it idles good, MAF on GTO is messed up & its idles rough lol, check to see if u have a vaccume leak
Old Jun 18, 2012 | 10:00 PM
RED DEVIL
Hey space. Im not sure what it is for sure. I havent changed the fuel filter yet since i got it. But it runs great other than this little hang up issue.
I dont think it is vacuum either. I have plenty on my obd scanner. I might take a video of it to help out
Old Jun 18, 2012 | 10:31 PM
Mr Grizzly Mint's Avatar
Check Throttle body too. After you get it off if you can see light around the edge its good if not then it needs cleaned. I was going to say MAF also but if it idels smooth then prob not MAF.
Old Jun 19, 2012 | 02:23 AM
Imo it sounds like a tranny related issue like its not downshifting or the torque converter like you said
Old Jun 19, 2012 | 02:51 PM
You can't change the fuel filter, that's why you haven't :p
